Philips Light Temperature over MQTT
Hi there,
I have a philips being lamp which is controlled with mqtt. When I try to set the light temperature it try to do this with lightmode. But the light isn’t changing.
Any ideas how to change to light_temperature instead? Since it’s set with this attribute.
So I have the Control which mqtt messages are sent?
Im just startet with home Assistant and try to connect my devices via MQTT from a Homey.
Greetings
