Hey guys!
i own a couple of those sensors and want to have an automation based on the current temperature.
But i noticed that its updating only every 5 minutes.
Do your know whether there is an option to increase that frequency?
General idea:
I like have alexa playing music when showering . Currently, I have two sensors, of which one tracks presence within the bathroom and another just for the shower. But I like to reduce it to one.
I could place it to notice presence everywhere, but than i dont know how it could distinguish between bathroom and shower.
You can’t change this and if you could this would be a huge drain on your batteries. Also humidity is better than temperature to detect if someone is showering. Does your temperature increase pretty fast after you start the shower?
Hey,
thanks for your answer.
I thought that there is a way pushing the sensor to check temperature each minute in case of movement.
Yes, the temperature increases pretty fast when showering since the sensor is close above the shower. i can see it in the logs.
But for humidity, i would also need another sensor, dont i?
