Philips Sensor not working on deCONZ
Hello all.
I have a Philips Hue Sensor as well the Philips bridge. I was not happy with the latency I was getting from the sensor, it always took 1 to 3 seconds to have motion detection triggered on HA.
I read somewhere that getting the sensor setup outside of Philips bridge and use deCONZ would make things better and faster, so I got a Conbee II for that.
However, when I pair the sensor with deCONZ, it only gathers the battery level data, it does not return data for motion, temperature or light. See here: https://share.getcloudapp.com/o0uq62kB
This is the first time I try a Conbee II, so I’m a bit lost here. Although, pairing the sensor was very straightforward.
TIA
I’d try removing the sensor and adding it again. Do you see the sensor in HA?
I tried that already. And yes, I do see the sensor in HA. Only the battery entity has a value, the others say “Unknown”.
(The picture shows the motion sensor entity as Clear, but it’s not working, it’s always Clear regardless of movement or not)
Did you remove it from the Hue bridge before adding it to DeCONZ? Does it still work with the Hue bridge? How did you pair it, pressing the button for 10 seconds?
I did remove it from HA before re-pairing it in deCONZ. And yes, by pressing the button for around 10 seconds.
