I noticed a couple of philips outlets that have independent plugs that can be controlled by Google home and Alexa, any luck to make this work with home assistant?
Philips 6 Outlet Smart Surge Protector, 4 Ft Braided Cord, Individual Control, 1080 Joule, Compatible with Alexa, Google Home, Bluetooth Set Up, No Hub Required, ETL Listed, White, SPP9034WB/37 https://a.co/d/7gr9PCW
Philips 5-Outlet Extender Surge Protector, Wall Tap, 2 Independent Wi-Fi Outlets, 3-Prong, 490 Joules, Voice Controlled Through Amazon Alexa and Google Assistant, ETL Listed, White, SPP3461WF/37 https://a.co/d/2YTOZ4K
I also have a Philips smart power strip that uses the SmartSelect app. Seems like it’s made by Jasco for Philips. Maybe this is just coincidence, but shortly after plugging in and setting up the power strip, home assistant send it found a new Tuya device and wants me to configure it. I’m pretty sure I don’t have anything Tuya on my network.
Hopefully this information is useful to someone trying to get an integration added for these products.
EDIT: I had unplugged the power strip for a few days and the Tuya integration went away since I hadn’t configured it. Next time I plugged the power strip in the Tuya integration showed up again. So it’s definitely related. I was unable to configure the integration since I don’t have anything else Tuya and Tuya doesn’t recognize the power strip.
