I expect I might be missing the obvious, I’ve searched the forums and not found or missed the answer to this question.
I have the above motion sensor connected using ZHA (Zigbee Home Automation) integration. I know there are adjustable options i.e motion sensitivity because I had It previously connected to Hubitat and could do that.
How do I do It on Home Assistant?
After sometime I’ve actually solved my own problem, I decided to post as It just might help someone else.
First I found that If you go to your device and look In “Manage clusters”, you can find the setting you are after. Reading the value worked fine but attempting to set it did failed.
Setting the value In Developer Tools>Services>zha.set_zigbee_cluster_attribute did work.
