Philips SML002 Outdoor Motion Binary Sensor Hangs?
Hi Folks,
I have a binary sensor “binary_sensor.philips_sml002_xxxxxxxx_2_1030” entity which is my outside motion for the front of the house. This works fine…generally.
Sometimes I see this motion detected binary sensor “on” for hours. No automations that run with it will trigger, as the motion (transition from off to on) isn’t detected. I can see the sensor working by the LED on the unit, but Hassio doesn’t see it. If I reboot (or maybe reload) then all is well and the same sensor, without intervention, is working again.
Every other ZHA device seems to work, there’s no network congestion issue.
The log doesn’t seem odd.
Does something just shut down on Hass that I need to reset from time to time?
Thanks,
Ambi
