Philips TV component working with jointspace 6 Non Android TVs
Hey guys, I renewed my tv with a Philips 65PUS6162 last january, and I was pretty sad, as the API changed and it was not supported by the existing API (I had the same model in 43" that worked with the old API). So I had no feedback about the TV in terms of Power Status, channel, source or volume.
I have just seen that 4 days ago there was some movement on the github of the ha philipsjs
https://github.com/danielperna84/ha-philipsjs
So I decided to check it.
I changed the init.py from /srv/homeassistant/lib/python3.6/site-packages/haphilipsjs$ to the one updated on the github page and voila!!
I have seen that the HA component calls ha_philipsjs==0.0.4 so, I guess that the next step should be the githab author to pump the release tag to 0.0.5 and the component author to call it. But meanwhile this is a workaround.
I have now power status, volume control, even a list of channels from HA
Hope it helps
You can check your API version in the following way:
http://yourtvip:1925/x/system, x being the API version number from 1 to 6
I have pushed the new package to pypi. Now only the version number needs to be changed. This will be included in the next HASS release.
Pretty new to the home assistant stuff, but i like what i am already abble to do.
Question i also have a recent (6 months old) Philips TV (non android) that i would like to integrate with home assistant.
But i does not seem to work, if i acces an example from the jointspace site like :
http://ip-address:1925/1/examples/ambilight/ambilight.html
(with correct IP) i get a forbidden message in my browser.
My api version seems to be 6 as this link is working http://yourtvip:1925/6/system
I was looking for the init.py but i do not seem to be able to find it…
Help is much appreciated
What I have is this, the only thing I can do is set the volume and turn the TV off.
media_player:
      - platform: philips_js
        host: IP-of-your-TV
        api_version: 6 #Don't know if the 6 does something though
