Hey Guys,
I´ve recently went to the trouble of creating a list of all my Philips TV Remote Buttons.
My Goal was to Control my TV with another remote.
The list contains the Codes for Tasmota and ESP Home.
Since I found so many help in this Forum i want to share my Result.
My ESP Home flashed Device:
IR Remote
Example ESP Home Config snippet:
esp8266:
board: esp01_1m
remote_transmitter:
pin: GPIO14
carrier_duty_percent: 50%
remote_receiver:
pin:
number: GPIO5
inverted: true
mode:
input: true
pullup: true
# high 55% tolerance is recommended for some remote control units
#tolerance: 55%
dump: all
binary_sensor:
- platform: remote_receiver # Volume UP NEW Remote
internal: true
nec: # The Received Code from the "NEW" Remote
address: 0x1308
command: 0x9C63
on_press:
- button.press: volumeup
button:
on_press:
- remote_transmitter.transmit_rc6:
address: 0x00
command: 0x10
# repeat:
# times: 4
# wait_time: 100ms
The List
My TV: Philips 65OLED803/12 Year 2020
"PowerOff"
ESP-Home: RC5 address=0x00, command=0x3D
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x83D","DataLSB":"0x10BC","Repeat":0}
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x3D","DataLSB":"0xBC","Repeat":0}
"PowerOn"
ESP-Home: RC5 address=0x00, command=0x3F
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x83F","DataLSB":"0x10FC","Repeat":0}
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x3F","DataLSB":"0xFC","Repeat":0}
"PowerToggle"
ESP-Home: RC6 address=0x00, command=0x0C
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0xC","DataLSB":"0x30","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1000C","DataLSB":"0x800030","Repeat":0}
"0"
ESP-Home: RC6 address=0x00, command=0x00
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10000","DataLSB":"0x800000","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x","DataLSB":"0x","Repeat":0}
"1"
ESP-Home: RC6 address=0x00, command=0x01
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1","DataLSB":"0x80","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10001","DataLSB":"0x800080","Repeat":0}
"2"
ESP-Home: RC6 address=0x00, command=0x02
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10002","DataLSB":"0x800040","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x2","DataLSB":"0x40","Repeat":0}
"3"
ESP-Home: RC6 address=0x00, command=0x03
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10003","DataLSB":"0x8000C0","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x3","DataLSB":"0xC0","Repeat":0}
"4"
ESP-Home: RC6 address=0x00, command=0x04
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x4","DataLSB":"0x20","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10004","DataLSB":"0x800020","Repeat":0}
"5"
ESP-Home: RC6 address=0x00, command=0x05
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10005","DataLSB":"0x8000A0","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x5","DataLSB":"0xA0","Repeat":0}
"6"
ESP-Home: RC6 address=0x00, command=0x06
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x6","DataLSB":"0x60","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10006","DataLSB":"0x800060","Repeat":0}
"7"
ESP-Home: RC6 address=0x00, command=0x07
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10007","DataLSB":"0x8000E0","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x7","DataLSB":"0xE0","Repeat":0}
"8"
ESP-Home: RC6 address=0x00, command=0x08
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x8","DataLSB":"0x10","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10008","DataLSB":"0x800010","Repeat":0}
"9"
ESP-Home: RC6 address=0x00, command=0x09
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x9","DataLSB":"0x90","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10009","DataLSB":"0x800090","Repeat":0}
"Mute"
ESP-Home: RC6 address=0x00, command=0x0D
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0xD","DataLSB":"0xB0","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1000D","DataLSB":"0x8000B0","Repeat":0}
"VolumeDown"
ESP-Home: RC6 address=0x00, command=0x11
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x11","DataLSB":"0x88","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10011","DataLSB":"0x800088","Repeat":0}
"VolumeUp"
ESP-Home: RC6 address=0x00, command=0x10
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10","DataLSB":"0x8","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10010","DataLSB":"0x800008","Repeat":0}
"ChannelPrev"
ESP-Home: RC6 address=0x00, command=0x0A
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0xA","DataLSB":"0x50","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1000A","DataLSB":"0x800050","Repeat":0}
"ChannelDown"
ESP-Home: RC6 address=0x00, command=0x21
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x21","DataLSB":"0x84","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10021","DataLSB":"0x800084","Repeat":0}
"ChannelUp"
ESP-Home: RC6 address=0x00, command=0x20
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x20","DataLSB":"0x4","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10020","DataLSB":"0x800004","Repeat":0}
"DirectionDown"
ESP-Home: RC6 address=0x00, command=0x59
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x59","DataLSB":"0x9A","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10059","DataLSB":"0x80009A","Repeat":0}
"DirectionLeft"
ESP-Home: RC6 address=0x00, command=0x5A
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x5A","DataLSB":"0x5A","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1005A","DataLSB":"0x80005A","Repeat":0}
"DirectionRight"
ESP-Home: RC6 address=0x00, command=0x5B
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x5B","DataLSB":"0xDA","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1005B","DataLSB":"0x8000DA","Repeat":0}
"DirectionUp"
ESP-Home: RC6 address=0x00, command=0x58
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x58","DataLSB":"0x1A","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10058","DataLSB":"0x80001A","Repeat":0}
"OK"
ESP-Home: RC6 address=0x00, command=0x5C
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x5C","DataLSB":"0x3A","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1005C","DataLSB":"0x80003A","Repeat":0}
"Stop"
ESP-Home: RC6 address=0x00, command=0x31
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x31","DataLSB":"0x8C","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10031","DataLSB":"0x80008C","Repeat":0}
"Play"
ESP-Home: RC6 address=0x00, command=0x2C
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x2C","DataLSB":"0x34","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1002C","DataLSB":"0x800034","Repeat":0}
"Rewind"
ESP-Home: RC6 address=0x00, command=0x2B
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x2B","DataLSB":"0xD4","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1002B","DataLSB":"0x8000D4","Repeat":0}
"Pause",Received
ESP-Home: RC6 address=0x00, command=0x30
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x30","DataLSB":"0xC","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10030","DataLSB":"0x80000C","Repeat":0}
"FastForward"
ESP-Home: RC6 address=0x00, command=0x28
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x28","DataLSB":"0x14","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10028","DataLSB":"0x800014","Repeat":0}
"Record"
ESP-Home: RC6 address=0x00, command=0x37
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x37","DataLSB":"0xEC","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10037","DataLSB":"0x8000EC","Repeat":0}
"Menu"
ESP-Home: RC6 address=0x00, command=0x57
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x57","DataLSB":"0xEA","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10057","DataLSB":"0x8000EA","Repeat":0}
"Subtitle"
ESP-Home: RC6 address=0x00, command=0x4B, toggle=0x
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x4B","DataLSB":"0xD2","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1004B","DataLSB":"0x8000D2","Repeat":0}
"Back"
"Teletext"
ESP-Home: RC6 address=0x00, command=0x3C
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x3C","DataLSB":"0x3C","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1003C","DataLSB":"0x80003C","Repeat":0}
"Search"
ESP-Home: RC6 address=0x00, command=0xB4
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0xB4","DataLSB":"0x2D","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x100B4","DataLSB":"0x80002D","Repeat":0}
"Green"
ESP-Home: RC6 address=0x00, command=0x6E
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x6E","DataLSB":"0x76","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1006E","DataLSB":"0x800076","Repeat":0}
"Red"
ESP-Home: RC6 address=0x00, command=0x6D
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x6D","DataLSB":"0xB6","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1006D","DataLSB":"0x8000B6","Repeat":0}
"Blue"
ESP-Home: RC6 address=0x00, command=0x70
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x70","DataLSB":"0xE","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10070","DataLSB":"0x80000E","Repeat":0}
"Yellow"
ESP-Home: RC6 address=0x00, command=0x6F
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x6F","DataLSB":"0xF6","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1006F","DataLSB":"0x8000F6","Repeat":0}
"Guide"
ESP-Home: RC6 address=0x00, command=0xCC
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0xCC","DataLSB":"0x33","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x100CC","DataLSB":"0x800033","Repeat":0}
"Info"
ESP-Home: RC6 address=0x00, command=0x0F
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0xF","DataLSB":"0xF0","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1000F","DataLSB":"0x8000F0","Repeat":0}
"PageDown"
"PageUp"
"Exit"
ESP-Home: RC6 address=0x00, command=0x9F
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x9F","DataLSB":"0xF9","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1009F","DataLSB":"0x8000F9","Repeat":0}
"Netflix"
ESP-Home: RC6 address=0x00, command=0x76
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x76","DataLSB":"0x6E","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10076","DataLSB":"0x80006E","Repeat":0}
"Settings"
ESP-Home: RC6 address=0x00, command=0xBF
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0xBF","DataLSB":"0xFD","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x100BF","DataLSB":"0x8000FD","Repeat":0}
"Ambilight"
ESP-Home: RC6 address=0x00, command=0x8F
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x8F","DataLSB":"0xF1","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1008F","DataLSB":"0x8000F1","Repeat":0}
"GooglePlay"
"Home"
ESP-Home: RC6 address=0x00, command=0x54
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x54","DataLSB":"0x2A","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10054","DataLSB":"0x80002A","Repeat":0}
"InputHdmi1"
ESP-Home: RC5 address=0x03, command=0x06
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0xC6","DataLSB":"0x63","Repeat":0}
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x8C6","DataLSB":"0x1063","Repeat":0}
"InputHdmi2"
ESP-Home: RC5 address=0x03, command=0x04
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x8C4","DataLSB":"0x1023","Repeat":0}
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0xC4","DataLSB":"0x23","Repeat":0}
"InputHdmi3"
ESP-Home: RC5 address=0x03, command=0x08
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0xC8","DataLSB":"0x13","Repeat":0}
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x8C8","DataLSB":"0x1013","Repeat":0}
"InputHdmi4"
ESP-Home: RC5 address=0x03, command=0x09
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x8F9","DataLSB":"0x109F","Repeat":0}
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0xF9","DataLSB":"0x9F","Repeat":0}
"InputYPbPr"
ESP-Home: RC5 address=0x03, command=0x39
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x839","DataLSB":"0x109C","Repeat":0}
Tasmota: {"Protocol":"RC5","Bits":12,"Data":"0x39","DataLSB":"0x9C","Repeat":0}
"Multiview"
ESP-Home: RC6 address=0x00, command=0x5D
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x5D","DataLSB":"0xBA","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x1005D","DataLSB":"0x8000BA","Repeat":0}
"Options"
ESP-Home: RC6 address=0x00, command=0x40
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x40","DataLSB":"0x2","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10040","DataLSB":"0x800002","Repeat":0}
"Signal"
ESP-Home: NEC address=0xFB04, command=0x6996
Tasmota: {"Protocol":"NEC","Bits":32,"Data":"0x20DF6996","DataLSB":"0x4FB9669","Repeat":0}
"SmartMenu"
"Source"
ESP-Home: RC6 address=0x00, command=0x38
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x38","DataLSB":"0x1C","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10038","DataLSB":"0x80001C","Repeat":0}
"TopPicks"
ESP-Home: RC6 address=0x00, command=0x74
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x74","DataLSB":"0x2E","Repeat":0}
Tasmota: {"Protocol":"RC6","Bits":20,"Data":"0x10074","DataLSB":"0x80002E","Repeat":0}
