I recently got a Philips vacuum mopping robot (Model xi3100/01) and would like to add it to Home Assistant. Unfortunately, there is currently no integration available.
Is there perhaps another way to add it, or is anyone working on a solution?
I just want to trigger the start command for it through Home Assistant.
And just couldn’t get it to work
It shows me “ez mode” and “ap mode” and ap mode requires a ssid from the robot that doesn’t match the app
The ez mode didn’t work it either.
Hey, I’m interested in running the vacuum robot without any vendor cloud. Is it possible to disable the internet access of the robot and use it with home assistant the way you described?
