How bizarre, I know there have been a lot of changes to the way discovery works in HA since v0.94 onwards, so this may be a bug, HA could be seeing something and wrongly assuming it’s a hue device.
If you feel brave you may be able to sniff packets with wireshark but this is far from straightforward.
did you mind spending 5 minutes reading the thread beside waisting 2 minutes for searching and providing totally useless advises here?
The mqtt ha (is for home assistant!) discovery you mentioned has literlly nothing to do with a (emulated) Philips hue integration.
Also it’s even written few posts up that discovery ignore for Philips hue is broken (actually it doesn’t use the discovery component anymore but zeroconf or ssdp - both don’t have a ignore implemented)
I don’t have any ssdp in my configuration.yaml. Guess the thingie is discovered with zeroconf then? Any possibility do disable this without collateral damage?
Emulated hue has nothing to do with discovery. That’s the thing that you’re all missing. Emulated hue is configured in home assistant and not automatically discovered. So I have no fucking clue what you’re even going on about.
I’m only repeating what’s in the thread because your responses are ambiguous. I honestly can’t tell if you’re trolling or not. Give a straight answer and you’ll get straight answers. Yes, I’m being serous. Although this morning it seems you’re taking this a little more seriously.
Is there any chance that this is discovered by ssdp rather than zeroconf? I can disable zeroconf the same way (and loosing probably almost all discovery functionalities?) or maybe even more?
if its the espurna(which i suspect it is) i have just tested it and enabling ssdp the espuran device came up in HA as a philips hue, removed SSDP and its gone
read bottom of this page about whats ssdp discovers
i think it espuran using the alexa integration that exposes it as Philips hue
Espurna uses this library for alexa support which confims it exposes them as Philips HUE https://bitbucket.org/xoseperez/fauxmoesp/src/master/
just tested this and it works
go into each espurna device you have
goto general, then right at the bottom of that page turn off alexa integration
save
reboot espurna
Thank’s for your investigations! But I have the alexa integration since always disabled on my espurna nodes
You had ssdp enabled in your last run (and just disabled alexa integration in espurna) and got rid of the permanent discovery notification in home assistant?
After fiddling around with one espurna node which behaved weird (didn’t proper update the sensor data via mqtt and the web interface of the node failed often) I found this one to be the cause of everything. Even though the alexa integration was disabled all time this mentioned espurna node did behave wrong (properly causing home assistant to discover it as Philip). A single restart of the node mcu did help but doing a full power cycle with unplugging the power source recovered the espurna thingie back to normal. One more restart of home assistant and finally the permanent notification is gone (for now)!
