Phillips Hue Dimmer Switch v2 (Zigmee2MQTT) action based
This is my take on using a Phillips Hue Dimmer Switch to control a single light entity.
It requires the manual creation of two input booleans prior to being imported/configured as a blueprint automation. An example of the 2 input booleans is provided below. Once those are added to your config.yaml and HA is restarted, you can configure an automation with the blueprint.
Please note that the dim function is currently hard coded to a “-10” step as my current attempts to invert the configured steps have been fruitless. I welcome any guidance/suggestions anyone has to rectify this.
Input booleans:
input_boolean:
  media_room_brighten:
    name: Brighten Media Room
    icon: mdi:sun
  media_room_dim:
    name: Dim Media Room
    icon: mdi:moon
Blueprint:
blueprint:
  name: Hue Switch – Switch Multi-Flow (Device + Light + Booleans)
  description: >
    Combines toggle, hold-to-brighten/dim (with repeat), and instant bright/dim.
    Select the MQTT device, the target light, and two input booleans.
  domain: automation
  input:
    remote_device:
      name: MQTT Button/Remote Device
      description: The MQTT device that emits action events (on_press, up/down hold, etc.)
      selector:
        device:
          integration: mqtt
    light_entity:
      selector:
        entity:
          domain: light
    brighten_boolean:
      selector:
        entity:
          domain: input_boolean
    dim_boolean:
      selector:
        entity:
    step_size:
      description: Amount to change brightness each tick (positive for brighten, negative for dim path).
      default: 10
      selector:
        number:
          min: 1
          max: 50
          step: 1
          mode: slider
    tick_ms:
      name: Repeat Interval (ms)
      description: How often to apply the step while holding.
      default: 500
      selector:
        number:
          min: 100
          max: 2000
          step: 50
          unit_of_measurement: ms
mode: parallel
max: 10
  # Button actions from the MQTT device
  - id: toggle
    platform: device
    domain: mqtt
    device_id: !input remote_device
    type: action
    subtype: on_press
  - id: brighten_hold
    platform: device
    domain: mqtt
    type: action
    subtype: up_hold
  - id: brighten_release
    platform: device
    domain: mqtt
    type: action
    subtype: up_hold_release
  - id: dim_hold
    platform: device
    domain: mqtt
    type: action
    subtype: down_hold
  - id: dim_release
    platform: device
    domain: mqtt
    type: action
    subtype: down_hold_release
  - id: instant_bright
    platform: device
    domain: mqtt
    type: action
    subtype: up_press_release
  - id: instant_dim
    platform: device
    domain: mqtt
    type: action
    subtype: down_press_release
  # State triggers to start the repeat loops
  - id: brighten_loop
    platform: state
    entity_id: !input brighten_boolean
    to: 'on'
  - id: dim_loop
    platform: state
    entity_id: !input dim_boolean
    to: 'on'
  - choose:
      # Toggle light
      - conditions: "{{ trigger.id == 'toggle' }}"
        sequence:
          - service: light.toggle
              entity_id: !input light_entity
              transition: 1
      # Hold to brighten: set boolean
      - conditions: "{{ trigger.id == 'brighten_hold' }}"
        sequence:
      # Release brighten: unset booleans (mirrors your original behavior)
      - conditions: "{{ trigger.id == 'brighten_release' }}"
        sequence:
          - service: input_boolean.turn_off
              entity_id:
                - !input brighten_boolean
                - !input dim_boolean
      # Hold to dim: set boolean
      - conditions: "{{ trigger.id == 'dim_hold' }}"
        sequence:
      # Release dim: unset boolean
      - conditions: "{{ trigger.id == 'dim_release' }}"
        sequence:
      # Instant 100%
      - conditions: "{{ trigger.id == 'instant_bright' }}"
        sequence:
          - service: light.turn_on
              brightness_pct: 100
              transition: 1
      # Instant 5%
      - conditions: "{{ trigger.id == 'instant_dim' }}"
        sequence:
              brightness_pct: 5
              transition: 1
      # Brighten loop while boolean stays on
      - conditions: "{{ trigger.id == 'brighten_loop' }}"
        sequence:
          - repeat:
              while:
                - condition: state
                  state: 'on'
              sequence:
                    brightness_step: !input step_size
                - delay:
                    milliseconds: !input tick_ms
      # Dim loop while boolean stays on
      - conditions: "{{ trigger.id == 'dim_loop' }}"
        sequence:
          - repeat:
              while:
                - condition: state
                  state: 'on'
              sequence:
                    brightness_step: -10
                - delay:
Hi, I really like your blueprint. But can you show how your input boolean looks?
For me it´s not working…
