Phillips Hue Integration not working since update
I have updated Home Assistant Core in response to the Security Bug update request. Phillips Hue integration no longer discovering Hue hub. Anybody else having Hue issues since the latest update?
Running HA Core on Unraid with Unraid App/Docker, Official HomeAssistant version.
I just updated my HA (installed on rpi) to 1.3 and right after HA restarted 1.4 is available. Bad timing on my part.
Any hoot, all the integrations on my end came up. No breaks or issues as I can see so far. I do notice from time to time, after a restart of HA, some integrations do not come back up. Example: broadlink, amazon, weatherbit. For those it is a simple of hitting the reload button in the integration section for each of them.
You can try doing that for Phillps Hue integration to see if that works or try a restart of HA again. Another thing to try is to to unplug the network cable from phillp hue hub. Wait a few seconds and plugging it back in.
HA restart - No dice.
I can try unplugging Hue from the network, but I fail to see what that will do (Hue is presenting a client-side assigned IP.) HA is discovering other things on the network (Chromecasts, Apple TV, Printers…Hue should be the last thing it has a problem finding…and it didn’t before the update)
No. 2021.1.4 running (auto-updated) and Hue still works.
I’m guessing UnRaid Docker issues then. (My server is shutdown for the moment…lot of snow here + rural power grid…I tend to power things down when it starts to get “iffy”). I’ll take another stab at when things get more stable.
I had the same thing happen. I updated to the 2021.1.5 but then all my Philips Hues stop showing up. I deleted the integration and redid it but no joy getting it to work.
I’ve redone my Hass instance on a Debian install (Supervised & supported) and removed it from my Unraid server (Core only). Hue works fine on that…in fact EVERYTHING works fine on that. (A friend passed an old Dell Precision T3500 server to me that I’ve been itching to slap a drive in and try out anyway). I’ll keep my UnRaid up for media service.
And it updates fine, which is good since it sounds like there may be more updates to come if they find more security issues.
Have migrated back to Core on Unraid. This time around, Hue integration works. No clue why. But long & short, I’m warming up to Core on UnRaid. Marking solved.
