Phillips Hue Remote Question
Anyone know if this remote can be used in HA zigbee to control non Hue lights?
Is this a ZigBee remote? I thought this is connected directly to a bulb. Can you control this remote with the Hue hub?
Not too sure to be honest. I think it connects to the hub
https://www.amazon.co.uk/Philips-Colours-Changing-Integrated-Control/dp/B008B4DC7K
I think only the light connects to the hue hub, I don’t think that you can use this remote to control other lights that are not connected to the remote with the original Hue hub.
I manged to pair the LivingColors light to ZHA thanks to a dimmer switch. Not the remote…
If this can inspire someone :slight_smile:
I followed this simple steps :
  1. Power the lamp
  2. Press both the I and 0 buttons of à dimmer switch for 10 seconds closeby the lamp : it will flash.
  3. Unplug / Replug the lamp and start the discovery process in ZHA
In video here : How to Factory Reset Philips Hue Bulbs using a Dimmer Switch - YouTube
Found while struggling on this website, thanks to them :pray:t2:
