Looks like it is input_number now. I have everything working except the icons for Alarm time, Fade-in start time and Fade-in duration are all different. It looks like this:
As a home-assistant newbee - how can I integrate this into my home-assistant setup? I have already connected my hue bridge and can control my light’s but I’m struggling to get the yaml files right. Which is the latest / best version of this and how does one integrate it?
Thanks for your help!
My current working setup is shown below. I can’t figure out how to edit the original post above…
Note that I use the old style of adding automations (“automation old:” instead of dedicated automations.yaml file).
input_number:
wakeup_hour:
icon: mdi:clock-in
initial: 6
min: 0
max: 23
step: 1
wakeup_minutes:
icon: mdi:clock-in
initial: 30
min: 0
max: 55
step: 5
wakeup_duration:
name: Light fade-in duration
icon: mdi:clock-in
initial: 10
min: 5
max: 60
step: 5
input_boolean:
wakeup:
name: 'Enable wakeup light'
icon: mdi:power
initial: off
wakeup_weekends:
name: 'Wakeup weekends'
icon: mdi:power
initial: off
sensors:
wakeup_alarm_time:
friendly_name: 'Alarm time'
value_template: '{% if states.input_number.wakeup_hour.state|length == 3 %}0{% endif %}{{ states.input_number.wakeup_hour.state | int }}:{% if states.input_number.wakeup_minutes.state|length == 3 %}0{% endif %}{{ states.input_number.wakeup_minutes.state | int }}'
sensors:
wakeup_start_time_lights:
friendly_name: 'Fade-in start time'
value_template: >
{% if states.sensor.wakeup_alarm_time and states.input_number.wakeup_duration %}
{% set alarmtime = states.sensor.wakeup_alarm_time.state %}
{% set alarm_hour = alarmtime.split(":")[0] | int %}
{% set alarm_min = alarmtime.split(":")[1] | int %}
{% set light_dur = states.input_number.wakeup_duration.state | int %}
{% set alarm_min_light = alarm_min - light_dur %}
{% if alarm_min_light < 0 %}
{% set alarm_min_light = alarm_min_light + 60 %}
{% set alarm_hour_light = alarm_hour - 1 %}
{% if alarm_hour_light < 0 %}{% set alarm_hour_light = 23 %}{% endif %}
{% if alarm_hour_light < 10 %}0{% endif %}{{ alarm_hour_light}}:{% if alarm_min_light < 10 %}0{% endif %}{{ alarm_min_light }}
{% else %}
{% if alarm_hour < 10 %}0{% endif %}{{ alarm_hour }}:{% if alarm_min_light < 10 %}0{% endif %}{{ alarm_min_light }}
{% endif %}
{% endif %}
sensors:
wakeup_fadein_duration:
friendly_name: 'Fade-in duration'
value_template: '{{ states.input_number.wakeup_duration.state | int }}'
unit_of_measurement: 'min'
group:
wakeuplight:
control: hidden
entities:
- sensor.wakeup_alarm_time
- sensor.wakeup_start_time_lights
- sensor.wakeup_fadein_duration
- input_number.wakeup_hour
- input_number.wakeup_minutes
- input_number.wakeup_duration
- input_boolean.wakeup
- input_boolean.wakeup_weekends
automation old:
- alias: 'WakeUp Light Bedroom'
hide_entity: True
platform: template
value_template: '{{ states.sensor.time.state == states.sensor.wakeup_start_time_lights.state }}'
condition:
condition: and
conditions:
- condition: state
entity_id: input_boolean.wakeup
state: 'on'
- condition: or
conditions:
- condition: state
entity_id: input_boolean.wakeup_weekends
state: 'on'
- condition: time
weekday:
- mon
- tue
- wed
- thu
- fri
service: script.wakeup_bedroom
script:
wakeup_bedroom:
alias: 'Wakeup lighting, smooth transition'
sequence:
- service: light.turn_on
data_template:
entity_id: light.soverom
brightness: 1
kelvin: 1000
- delay:
seconds: 1
data_template:
brightness: 64
kelvin: 2000
transition: '{{ (( states.input_number.wakeup_duration.state | float * 60 / 4 )| round ) | int }}'
- delay: '00:00:{{ (( states.input_number.wakeup_duration.state | float * 60 / 4 )| round ) | int }}'
data_template:
brightness: 128
kelvin: 3000
data_template:
brightness: 191
kelvin: 4000
data_template:
brightness: 255
kelvin: 5000
So i got it on my screen but i get these errors:
2018-01-11 23:29:58 ERROR (MainThread) [homeassistant.config] Invalid config for [script]: [wakeup_bedroom] is an invalid option for [script]. Check: script->script->test_push->wakeup_bedroom. (See /home/homeassistant/.homeassistant/configuration.yaml, line 45). Please check the docs at https://home-assistant.io/components/script/
2018-01-11 23:29:58 ERROR (MainThread) [homeassistant.setup] Setup failed for script: Invalid config.
2018-01-11 23:30:13 WARNING (MainThread) [homeassistant.setup] Setup of light is taking over 10 seconds.
2018-01-11 23:30:51 ERROR (MainThread) [homeassistant.components.sensor.template] Could not render template Fade-in start time: UndefinedError: list object has no element 1
ANy idea what it could be?
Thanks for this, it works amazing!
For those that have issues with triggering the automation you may need to enable the time sensor:
I’m using hue color lamps and made a sequence that goes from very dim red to dim yellow to brighter white
I found that sometimes the transition would not happen and think it is due to delay being the same, so I just do transition minus 1 second:
bedroom_rear_wakeup_light:
sequence:
data_template:
entity_id: group.bedroom_rear_bed_lights
brightness: 0
rgb_color: [128,0,0]
- delay:
seconds: 0
data_template:
brightness: 1
- delay:
seconds: 1
data_template:
brightness: 16
transition: '{{ (( states.input_number.bedroom_rear_wakeup_duration.state | float * 60 / 7 -1 ) | round ) | int }}'
- delay: '00:00:{{ (( states.input_number.bedroom_rear_wakeup_duration.state | float * 60 / 7 ) | round ) | int }}'
data_template:
brightness: 32
rgb_color: [192,64,0]
transition: '{{ (( states.input_number.bedroom_rear_wakeup_duration.state | float * 60 / 7 - 1 ) | round ) | int }}'
data_template:
brightness: 48
rgb_color: [224,128,32]
data_template:
brightness: 96
rgb_color: [255,176,96]
data_template:
brightness: 112
rgb_color: [255,224,160]
data_template:
brightness: 128
rgb_color: [255,255,224]
data_template:
brightness: 144
rgb_color: [240,255,255]
edit: improved colors for a smoother transition (i hate too much greens), also the first step in the sequence which sets the color with a 0 brightness may (or may not) reduce the initial flash that happens when the lights were previously turned off with a high brightness setting, may need to find a better workaround for that
I’ve also tried setting the colour before turning the lamp on, but I do not think this work when the brightness is 0. The lamp needs to turn on (brightness > 0) to change color.
It should not be necessary to decrease the transition with 1 second. When a new command is sent to hue the current transition will be terminated anyway…
Yes I noticed the light still flashes with that first step. I didn’t know the transition is canceled so guess I can drop the -1
Thank’s so much, combining the variable fade-in time with a colored sunrise is exactly what I was looking for. Sometimes the light flashes at the start but this seems to be varying (I can’t make it always flash).
Hum…
Can’t seem to get this to work, or even figure out where it is crashing.
I have *.automations on Debug level, and this is all I’m getting:
018-05-25 16:38:01 INFO (MainThread) [homeassistant.components.automation] Executing WakeUp Light Bedroom
So it is running, but not actually doing anything. I did add the date sensor, but that didnt help. I also (obviously) changed the name of my light group for Hue.
Any thoughts on how to debug / trace the issue?
**EDIT:
Ha! found the issue in the last place I look… the info “button”. I renamed the script section while testing and that was the issue. Works great! Thanks!
I have the same issue… any ideas?
Nope… Not working
Might be a silly question but why don’t you try the built in routines in the Hue App? Seems to be possible natively to smooth in at wake up ? And very reliable too…
It’s too simple and not integrated
I want to trigger other stuf at the same time after my alarm goes off (connected to HA).
My alarm goes off a different time everyday.
sure, you’re both right, Hue automation is quite simple, and coming from Hassio or Ha quite a leap back in possibilities. Still people are creating the labs, which we can use native, and I believe also through the api, hence via Ha. Switching my motion sensors like that too, works super.
Hue has it advantages in stability and most of all reliability compared to Ha though. Thats why I always try to use the Hue native services/lights/sensors etc and call these in the Ha setup if needed.
I havent tested the labs. Any good ones? Will read on it this weekend. Maby its a solution to my problem.
mostly christmas lights, fake thunders and other flashes.
in the regular routines you might find wake up strategies.
also just so you know theres the circadian lights settings by @mastermarkush adapting the lights to the circadian settings of the day Circadian light with Philips Hue, independent from world clocks ;-) Nice!
I was joking but… my plan is the following:
I have two sensors on both sides of my bed turning on courtesy lights when we wake up / get out of bed.
So meant to 1)
Turn progressively louder some soft music through google mini .
2) if I wave my hand in front of the sensor or shout at the mini ok google snooze (least effort strategy: first scenario my partner is in bed and sleeping. Second I am alone
3) I stop the hand on the sensor for a few seconds or tell the mini to stop: stop the alarm. I have to figure out if it is possible to check this gesture somehow. Any idea welcome. Other option would be,perhaps even better, to use a bed occupancy sensor and turn the snooze in a turn off if any of the occupants leave the bed.
Next step: turn on the Nespresso and brew the Coffee
Try that with hue
love this integration, and just started to play with it,
thinking it would be great to be able to set it up with different lamps. is that possible?
either to change lamp with a switch? or do i need to do a separate configuration with everything?
i try to intrgrate this in my HA. It is not working for me. As you van see the sensors fade-in start and duration and alarm time do not work.
I also can’t get the script to work. I think the input_numbers are not getting there state pass over to the transision part in the script. The light do go on with brightness 1 but don’t get brighter.
I think it has to do with the last part
There the transition time is set but maybe this is wrong?
