Phillips Hue Wakeup Light with fade-in
I’ve made a wakeup light that uses the smooth transition on a Phillips Hue group (Room).
You can set the transition duration in minutes so that the maximum brightness is reached on “Alarm time”.
configuration.yaml
input_slider:
  wakeup_hour:
    icon: mdi:clock-in
    initial: 6
    min: 0
    max: 23
    step: 1
  wakeup_minutes:
    icon: mdi:clock-in
    initial: 30
    min: 0
    max: 55
    step: 5
  wakeup_duration:
    name: Light fade-in duration
    icon: mdi:clock-in
    initial: 10
    min: 5
    max: 60
    step: 5
input_boolean:
  wakeup:
    name: 'Enable wakeup light'
    icon: mdi:power
    initial: off
  wakeup_weekends:
    name: 'Wakeup weekends'
    icon: mdi:power
    initial: off
    sensors:
      wakeup_alarm_time:
        friendly_name: 'Alarm time'
        value_template: '{% if states.input_slider.wakeup_hour.state|length == 3 %}0{% endif %}{{ states.input_slider.wakeup_hour.state | int }}:{% if states.input_slider.wakeup_minutes.state|length == 3 %}0{% endif %}{{ states.input_slider.wakeup_minutes.state | int }}'
    sensors:
      wakeup_start_time_lights:
        friendly_name: 'Fade-in start time'
        value_template: >
          {% if states.wakeup_alarm_time and states.input_slider.wakeup_duration %}
          {% set alarmtime = states.sensor.wakeup_alarm_time.state %}
          {% set alarm_hour = alarmtime.split(":")[0] | int %}
          {% set alarm_min = alarmtime.split(":")[1] | int %}
          {% set light_dur = states.input_slider.wakeup_duration.state | int %}
          {% set alarm_min_light = alarm_min - light_dur %}
          {% if alarm_min_light  < 0 %}
          {% set alarm_min_light = alarm_min_light + 60 %}
          {% set alarm_hour_light = alarm_hour - 1 %}
          {% if alarm_hour_light < 0 %}{% set alarm_hour_light = 23 %}{% endif %}
          {% if alarm_hour_light < 10 %}0{% endif %}{{ alarm_hour_light}}:{% if alarm_min_light < 10 %}0{% endif %}{{ alarm_min_light }}
          {% else %}
          {% if alarm_hour < 10 %}0{% endif %}{{ alarm_hour }}:{% if alarm_min_light < 10 %}0{% endif %}{{ alarm_min_light }}
          {% endif %}
          {% endif %}
    sensors:
      wakeup_fadein_duration:
        friendly_name: 'Fade-in duration'
        value_template: '{{ states.input_slider.wakeup_duration.state | int }}'
        unit_of_measurement: 'min'
group:
  wakeuplight:
    control: hidden
    entities:
      - sensor.wakeup_alarm_time
      - sensor.wakeup_start_time_lights
      - sensor.wakeup_fadein_duration
      - input_slider.wakeup_hour
      - input_slider.wakeup_minutes
      - input_slider.wakeup_duration
      - input_boolean.wakeup
      - input_boolean.wakeup_weekends
automation old:
  - alias: 'WakeUp Light Bedroom'
    hide_entity: True
      platform: template
      value_template: '{{ states.sensor.time.state == states.sensor.wakeup_start_time_lights.state }}'
    condition:
      condition: and
      conditions:
        - condition: state
          entity_id: input_boolean.wakeup
          state: 'on'
        - condition: or
          conditions:
            - condition: state
              entity_id: input_boolean.wakeup_weekends
              state: 'on'
            - condition: time
              weekday:
                - mon
                - tue
                - wed
                - thu
                - fri
      service: script.wakeup_bedroom
script:
  wakeup_bedroom:
    alias: 'Wakeup lighting, smooth transition'
    sequence:
      - service: light.turn_on
        data_template:
          entity_id: light.bedroom
          brightness: 1
          xy_color: [0.3698, 0.3723]
      - delay:
          seconds: 1
        data_template:
          brightness: 255
          transition: '{{ states.input_slider.wakeup_duration.state | multiply(60) | int }}'
# EDIT: Everything below is not longer necessary as Hass now supports Hue natively!
script:
  wakeup_bedroom:
    sequence:
      - service: shell_command.wakeup_init
      - service: shell_command.wakeup_transition
shell_command:
  wakeup_init: "/home/homeassistant/.homeassistant/bash_scripts/phue_control.sh bedroom '{\"on\":true,\"bri\":1,\"xy\":[0.3698,0.3723],\"transitiontime\":50}'"
  wakeup_transition: "/home/homeassistant/.homeassistant/bash_scripts/phue_control.sh bedroom '{\"bri\":254,\"transitiontime\":{{ states.input_slider.wakeup_duration.state | multiply(600) | int }}}'"
EDIT-1: I created this “app” a long time ago and I just found out that hass now supports Phillips Hue natively which means that the bash script (phue_control.sh) below is no longer needed!
EDIT-2: Added input booleans
The two shell commands uses a bash script (phue_control.sh) that I wrote to be able to use the groups (Rooms) and simultaneous transition function. I used the instructions given here to create an API key and to find the ID’s for my hue groups and lights. The wakeup_init sets the color and minimum brightness and the wakeup_transition sets the transition time and target brightness (max=254).
phue_control.sh
#!/bin/bash
# INPUT: hue IP & api key
HOST=<YOUR HUE BRIDGE IP>
APIKEY=<YOUR KEY>
# group/light friendly name
FNAME=$1
# hue command
COMMAND=$2
# INPUT: specify hue type ("groups" or "lights") and ID
case $FNAME in
	bedroom)
		TYPE="groups"
		ID=2
	nattbord_lorentz)
		TYPE="lights"
		ID=1
	nattbord_karen)
		TYPE="lights"
		ID=2
	sofaspotter)
		TYPE="groups"
		ID=1
	spisebord)
		TYPE="lights"
		ID=3
esac
if [ "$TYPE" == "groups" ] ; then
	AS="action"
else
	AS="state"
fi
curl -X PUT -H "Content-Type: application/json" -d $COMMAND http://$HOST/api/$APIKEY/$TYPE/$ID/$AS
Very cool! And quite the savings on buying the Philips Alarm Clock.
I’m going to try this; I only have one lightstrip in the bedroom but I’m real sensitive to lights when I am sleeping so it may work in my case; thanks!
I created this “app” a long time ago and I just found out that hass now supports Phillips Hue natively which means that the bash script is no longer needed!
Replace the script with this:
script:
  wakeup_bedroom:
    sequence:
        data_template:
          brightness: 1
      - delay:
          seconds: 1
        data_template:
          brightness: 255
Very cool! I’m gonna have to try to implement this!
Actually I’m wondering what that xy color represents?
I have a similar setup here: https://github.com/Danielhiversen/home-assistant_config/blob/master/packages/alarm_clock.yaml
@Lorentz this is awsome, thanks for sharing!
However it seems your config is missing the setup for these 3 entities thats showed in your screenshot and also in the group settings:
Alarm time
Enable Wakeup light
Wakeup Weekends
Could you maybe update your example code?
Thanks!
Thanks! xy color is just one way of setting the color, you can use rgb if you want. Read more about it here: https://www.developers.meethue.com/documentation/core-concepts
Thank you:) Alarm time is one of the sensors defined. “Enable wakeup” and “wakeup weekends” are just regular input booleans. I will update the code later…
oh I know, I suppose I can just try some sample JSON to figure it out (not home right now) I was wondering what color that equated to.
Ok:) It’s a high kelvin white, to resamble daylight.
Updated code with input_boolean’s.
I don’t use the script to call the lights service, I just do it all in the automation like so.
- alias: 'wake up bedroom'
  hide_entity: True
    platform: template
  condition:
    condition: and
    conditions:
      - condition: state
        entity_id: device_tracker.lex_iphone
        state: home
      - condition: state
        state: 'on'
      - condition: or
        conditions:
          - condition: state
            state: 'on'
          - condition: time
            weekday:
              - mon
              - tue
              - wed
              - thu
              - fri
      entity_id: light.hue_go_1, light.hue_go_2
      profile: relax
    data_template:
      transition: '{{ states.input_slider.wakeup_duration.state | multiply(60) | float }}'
Hey guys,
Trying to get this to work but somehow my “wakeup_start_time_lights” sensor isn’t being set, resulting in it not working :confused:
Any idea as to why this is?
I had this working perfectly but my installs just started showing the same behaviour…
I think I found the error in the first line of the value template for the “wakeup_start_time_lights” sensor:
Change:
to:
{% if states.sensor.wakeup_alarm_time and states.input_slider.wakeup_duration %}
Somehow this worked in 0.51 (it shouldn’t), but not when I updated to 0.54.
@Kantraz @jamieb
Works like a charm thanks @Lorentz
That did the trick! The whole thing now looks like this:
  sensors:
      value_template: >
        {% else %}
        {% endif %}
        {% endif %}
I think you pasted the old version…
Thanks! Fixed it!
I get an error:
ERROR (MainThread) [homeassistant.loader] Unable to find component input_slider
Any idea how to fix it?
