Does anyone has any project to install phlex on hass.io to controle plex with google home/alexa?
I would like to know this as well. I know Phlex can be installed via docker and hass.io is built inside docker, but I’m not sure how and if we can just simply run Phlex besides home assistant
does the phlex docker work on raspberry pi? anyone tested this?
I didn´t test, I´m running on my wondows, but to works well need to be all time wake, and I don´t want to to leave it.But her eit says it could be workable on rasp pi3 https://github.com/d8ahazard/Phlex. I hope someone could transfor this in a add on or something like this.
Project is here
Tks this is great, I´ll try tonight, does it need any other configuration, I´ve already had on my windows with apache do I have to erase something disconect something?
it´s working very well tks very much
I currently have phlex tv running on Windows, but I’m going to try this set up.
On my Windows machine I have organizr behind nginx proxying all my Usenet programs. To get phlex tv to work I had to install apache too, which isn’t ideal.
So fingers crossed I can get it running on my hassio
thanks! Works fantastic…
I activate ssl and doesnt works
Nothing?
Please!
Can you help me? I’m trying to use… but it not works.
César.
ezar where did you stuck?
When I configure ssl, doesn’t works
just realized that mine it´s not working he´s active I can talk to phlex but he isn´t playing anything, anyone with this problem?
@ezar what´s the erros mensage it´s showing?
For the past weeks phlex is responding but not casting, I tryied to access th web ui but couldn´t anyone having problems?
me! we need to use latest beta
have you been able to use?
No. It’s not working!
