There were cool application that I used for a while Custom_component: PhoneTrack GPS device tracker but seem it is not working anymore…
I wondering how it is possible to replace it with RESTful calls. Basically I created following config in configuration.yaml:
rest_command:
phonetrack_get:
url: https://DOMAIN/index.php/apps/phonetrack/api/getlastpositions/TOKEN
# Or better this one more secure way
#url: !secret phonetrack_url_token
method: get
If you choice more secure way
you need to update / create secrets.yaml with URL:
phonetrack_url_token: https://DOMAIN/index.php/apps/phonetrack/api/getlastpositions/TOKEN
Now I can create automation to periodically calling this API and get data based on RESTful Command - Home Assistant example:
alias: "[RESTful] Get Last GPS Position"
description: >-
https://www.home-assistant.io/integrations/rest_command/#using-rest-command-response-in-automations
- platform: time_pattern
minutes: "5"
condition: []
- service: rest_command.phonetrack_get
metadata: {}
data: {}
response_variable: phonetrack_response
- if:
- condition: template
value_template: "{{ phonetrack_response['status'] == 200 }}"
then:
- alias: Parse data
variables:
state.entity_id: device_tracker.phonetrack_device_name
source_type: gps
friendly_name: Device Name
locations_lat: >-
phonetrack_response['content']['TOKEN']['Device Name']['lat']
locations_lon: >-
phonetrack_response['content']['TOKEN']['Device Name']['lon']
locations_accuracy: >-
phonetrack_response['content']['TOKEN']['Device Name']['accuracy']
locations_batterylevel: >-
phonetrack_response['content']['TOKEN']['Device Name']['batterylevel']
else:
- service: persistent_notification.create
title: Could not get GPS data via Phonetrack. Please check the logs.
message: "Http Response code is: {{ phonetrack_response['status'] }}"
mode: single
And get following data:
locations_lat: XX.yyyyyyy
locations_lon: XX.yyyyyyy
locations_accuracy: 2.61
locations_batterylevel: null
Seems light, but I have few Problems:
How to assign those GPS Values to the Person / Device to track location? I know that in a
But how it is assigned to it is still magic for me, because Object name on screenshot is/config/personI can do that, but here I do not have anything from my automation. Somehow it is working now and I have following output:
device_tracker.bmwand in automation it isstate.entity_id: device_tracker.phonetrack_bmw… Is it done via Friendly name? -
I there is a way to get rid of
TOKENin automation config?
Problem is that API answer is as following:
"TOKEN": {
"Device Name 1": {
"accuracy": 2.61,
"altitude": 111.6,
"batterylevel": null,
"bearing": 226.78,
"lat": xxxxx,
"lon": xxxxx,
"satellites": null,
"speed": 3.015,
"timestamp": 1707751858,
"useragent": "Ulogger"
"Device Name 2": {
"accuracy": 12.73,
"altitude": null,
"bearing": null,
"lat": xxxxx,
"lon": xxxxx,
"satellites": null,
"speed": null,
"timestamp": 1707748428,
"useragent": "browser"
And I need to go over it to get Device Name and Location…
- Can it be more general for “Device Name”? E.g. some variable?
