Hi.
Suddenly, and not after any update, my deCONZ integration is not working. - When i click it, i get the nowmal page, where i can selsct Phoscon or deCONZ … deCONZ is woring fine, but when i hit the Phoscon button, i just get: Websiden på
You can try to turn the addon off and back on to see if that helps. If not, try to reboot the host (computer/nuc/raspberrypi etc) if you haven’t already.
It would help if you also say what you’ve already tried to solve it next time.
Do you have discord by any chance?
Deconz has its own support channel. Maybe they can help you debug?
You could try to install portainer addon. Its software to manage your docker containers through a web gui. That could maybe show you more info in logs. And if it’s started or not. And if not start the container from there while monitoring the logs for possible errors
