I’m looking for a door open/close sensor which requires physical contact rather than using a magnet ans is battery powered. The use case is for a freezer door which sometimes sticks at a point where it is almost closed–close enough that magnet-based sensors I’ve tried show closed state even though the door is not fully closed. (It’s open enough so that the door seal isn’t tight and so the freezer thaws.)
You’re looking for a battery-powered RF contact sensor based on a microswitch.
That’s not nearly as common as one based on a reed switch and magnet (as you’ve discovered). You might have to build one from scratch or customize an existing reed/magnet sensor to use a microswitch.
FWIW, I use microswitches to detect the position of deadbolts. However, they’re all hard-wired (to an alarm panel).
The ZWave units that I’ve seen so far all have a Reed Switch that would support taking the switch out and putting a physical connection in instead - here’s a photo of a window/door sensor that actually has both, a Reed Switch (2) AND a connector (1):
I use it in my Honeywell alarms system as described here, but the principle is the same.
Looks almost identical to what I’ve used. It offers the choice of using it as Normally Closed (NC) or Normally Open (NO).
When modifying the reed/magnet sensor, check the reed switch’s state when the magnet is in contact (opened or closed). That’ll determine if you need to use the microswitch in NO or NC mode.
