Pi 3 B+ not finding Hass.io image
I am trying to install Hass.io on my Pi 3 B+ and when I flash the card and insert it my Pi does not find the image file as indicated by 7 blinking green lights. I am following the instructions to the letter and my Pi does boot other OS’s like rasbian and openhab. Any help would be appreciated.
How did you install home-assistant? using the Hass.io image for Raspberry Pi 3 or?
Using etcher and the pi 3 image from the downloads page on a 16 GB and a 32 GB micro sd card using Windows 10. I also tried different programs to flash the cards with the same results.
which image you are using? the hassio image or ?
Download the SD Formater make a full format to SD Card before write image by Etcher.
Download the image for home-assistant you want to use, example
https://home-assistant.io/getting-started/ <— scroll down see Download Hass.io image for Raspberry Pi 3 or alternative installation methods.
After write the image by etcher. plug in your rp3 and ethernet cable. This might takes about 20 mins for everything to load. For hass.io image you can access from browser with the same network of rp3 at http://hassio.local:8123
I tried your instructions and still the same results. I have no idea what is going on and I seem to be the only person who has this problem. I might just buy a new Pi 3 and see if that will fix my problem.
I had also problems to install Hass.io. I have donwload the image but it isn’t realy a image. What you download you must unpack that with winrar and then write the image. I don’t use Etcher but Win32DiskImager.
I did what you said. The Pi still can’t find the flashed image. I have tried using fresh downloads of the programs and 5 different computers with the same results. I have no idea what else to do.
Maybe a stupid question from me, but how do you put that card in the raspberry?
The contacts of the card must be directed upwards.
The contacts are facing the board, I can’t put it in any other way.
When you write the image an the disk and you open the explorer of your computer, what do you see then ?
The card seen likes mine. So I think there is something wrong with your pi.
Can you send it back to the store where you buy it ?
When you plugin the power without a card, is then the red light on ?
I get the red and green light. I have had the Pi for a year. It will run other operating systems lust fine. I installed openhab 2, Hassbian and both booted just fine.
And did you always use the same card ?
The card you use now, is that a high-rated SDHC card, at least 2 GB ?
I tried tree cards, 32 GB, 16 GB, 16GB. All class 10 cards. Two cards after 15 flashes died so now I only have one 16 GB left.
Then I have no idee what the problem is.
Have also tried to setup like this https://home-assistant.io/docs/installation/raspberry-pi/
Thanks for your help. If this way does not work then I will just put this project on the shelf for now.
I had a power issue on mine. With nothing in USB and wifi enabled it works. With Z-wave adapter plugged in it needed 2.5A to start properly :slight_smile:
Have you actually managed to install Hass.io on the latest Pi 3 B+? The installation guide for Hass.io says it not yet supported. But you succeeded?
