I’m attempting my first HA install, and my internet connection is via a Netgear Nighthawk M2 lte hotspot. It’s on the Optus cellular network and does NOT have a static IP (almost impossible to get static IP for cellular services in Australia).
I’m pretty illiterate when it comes to networking and coding.
The HA install progresses well, until the “HOME ASSISTANT” welcome shows up on the connected hdmi monitor.
I cannot connect to the home assistant control panel via a laptop browser connected by WIFI to the Netgear M2 network the specific address or the general address. It says connection timed out, reset, or rejected (or something similar)
The Pi 3b+ is hard wired to the netgear M2.
I assume I need to connect via the browser to set up account and continue installation?
Is the problem that the wifi hotspot doesn’t have static IP?
Are there any other ways I can install with only the Nighthawk M2 as my internet connection/router?
Your Pi is connected by cable, your PC over wifi through your LTE router ? Are you sure both are on the same subnet and there is no firewall on the router preventing both to connect to each other ? Can you connect your PC over cable too ? Ideally by using an external router / switch (put both the Pi and your PC on the external switch and plug that switch into your LTE router).
What’s the local IP address assigned to the Pi ? Most likely starting with 192 or 10, don’t worry, these are not public IPs but LAN IPs, noone can connect to these from the outside, they’re local to your own network.
