Apparently Pi 3B+ have no UASP support
Means no SSD TRIM.
https://www.jeffgeerling.com/blog/2020/uasp-makes-raspberry-pi-4-disk-io-50-faster
Means no SSD TRIM.
TRIM should be also possible without UASP
https://www.jeffgeerling.com/blog/2020/enabling-trim-on-external-ssd-on-raspberry-pi
https://wiki.archlinux.org/title/Solid_state_drive#External_SSD_with_TRIM_support
It might still depend on controller.
I have Kingston A400120G and VL711 controller and does not work.
Kingston website says A400 supports TRIM.
V
Did you follow the discription in the link to the archlinux wiki posted to get TRIM working?
This post also might help you:
I got this actually working yesterday. I did the steps found on the Arch Linux wiki, but it did not mention setting
discard_max_bytes
for the disk. Setting this to the correct value (and persisting it using an udev rule) has TRIM fully working for me on my Pi 3B
I’m trying no joy. Thanks BTW.
I checked my controller which is via VL711 say support UASP and the SSD is Kingston A400 120G which also say supports TRIM
https://www.via-labs.com/product_show.php?id=44
Kingston cant update firmware… got S3501103 - KSM says no updated firmware.
accoring to link
Specifications of KINGSTON SA400S37120G Drive with S3501103 Firmware it says Phison controller.
Run Phison tools also says unable to find SSD to update.
Anyways… just relied on manufacturer docs that controller and SSD supports trim.
I’m trying on Linux Lite live CD on a laptop to see if I can test TRIM.
sg_vpd -p bl /dev/sdb
Maximum unmap LBA count: 4194240
sg_readcap -l /dev/sda
Logical block length=512 bytes
echo $((4194240*512))
2147450880
set discard_max_bytes has been set.
cat /sys/block/sdb/device/scsi_disk/*/provisioning_mode
unmap
So umap has been set.
when I run fstrim -v / says the discard operation not supported.
I also tried blkdicard to wipe the SSD but got
blkdiscard: cannot open /dev/sdb2: Device or resource busy
Not sure how to enable in HAOS as very limited commands.
I opened port 2222 to connect to HAOS rather than container.
Got it working…
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 1.9G 1 loop /rofs
sdb 8:16 0 111.8G 0 disk
├─sdb1 8:17 0 50M 0 part
├─sdb2 8:18 0 111.2G 0 part /media/linux/A0B89657B8962C32
└─sdb3 8:19 0 508M 0 part
sdc 8:32 1 28.9G 0 disk
└─sdc1 8:33 1 28.9G 0 part /cdrom
sr0 11:0 1 1024M 0 rom
fstrim -v /media/linux/A0B89657B8962C32
/media/linux/A0B89657B8962C32: 85.1 GiB (91333144576 bytes) trimmed
Moving on…
Now how to do on HAOS
Lol… I was able to run the blkdiscard but forgot to document what I did.
I run hdparm, wipefs and at onepoint blkdiscard worked.
https://utcc.utoronto.ca/~cks/space/blog/linux/ErasingSSDsWithBlkdiscard?showcomments
dd if=/dev/zero of=/dev/sdX bs=1024k count=128; sync
Sorted out , TRIM now working on HAOS.
Awesome! Now you might want to correct the title of the thread to something like “Pi 3B+ SSD no UASP but TRIM possible”
I tried to find out if my P4 with my SSD on USB3 supports Trim.
I’ve accessed my HA using ‘SSH Server’, not to be mistaken by ‘Terminal & SSH’, which doesn’t give core access.
Had to additional install the packages util-linux
, lsscsi
and sg3_utils
to be able to enter all the required commands the above instructions show. Dispite all effort, sg_vpd -p bl /dev/sda
andsg_vpd -p lbpv /dev/sda
result in a sg_vpd failed: Operation not permitted
error.
Sync it seems a big risk just to enable trim/discard, I wonder anyone has other tricks up their sleeve.
I would not risk it, if you arent sure if your SSD and controller supports TRIM, dont do it directly on RPI4. They guys who did the guide already wrote a warning on it.
Test in a laptop or PC and run live linux CD.
I was going to buy RPI4 but for a few extra $ $200 CAD to be exact I was able to pickup a Dell 3060 which is way more powerfull and now in the process of migrating running Proxmox and container method. On top I am now running PiHole on same box.
Yeah, I’ve read the warnings, that’s why I’ve put in the effort to figure out if my hardware supports it. Big change it does, but I’m not willing to push my luck. Having HA crash isn’t my idea of fun. I was just hoping someone had an idea to work around the Operation not permitted
-error without shutting down and disconnecting the disk from HA.
