I’ve installed 32bit HomeAssistantOS via SD card on a Pi 400 and none of the bluetooth tracking integrations appear to work, nor am I able to pair a Flic button to the Pi with the flic community add on. I checked via the Terminal add on using bluetoothctl and the devices command, it says there is no default controller available, which suggests that Home Assistant can’t find the bluetooth adapter. I previously had an install of Raspbian on the Pi 400 and used a bluetooth mouse on it no problem, so I believe the hardware is ok but there’s something missing in my set up to activate it. Anyone else seeing this on a Pi 400?
