Pi 5 second SD card bricked
Update to 14.2 failed and my interface wasn’t accessible anymore. As I have a daily backup no big problem. Wrong, the problem exists after flashing the card with Raspberry Pi Imager 1.8.5. So I tried to format the SD card with every possible tool like Windows diskpart, Apple disk utility, SD Card formatter and so on… I just get a new card.
Is there any way to rescue the cards with all those partations? It’s not even 10$ each but still unnecessary.
$10 doesn’t sound like you’re buying high endurance SD cards, which you really should if you want to stick with the SD card format.
pi5 supports SSD. Get one. Using card is asking for problems.
That “endurance” (or durable) type cards are the wrong ones for this use case. :warning:
Do you mistake them for (expensive) “industrial” ones by chance? :thinking:
The best, when using SD cards, is (like the ha docs tell us) to use A1/A2 type cards.
Micro SD Card.
  • Ideally get one that is Application Class 2. Check for the label A2 on the card. Application Class 2 cards perform better especially on small read and write operations and are better suited to host applications.
  • Make sure to use a card that provides at least 32 GB.
The industrial type doesn’t make sense IMHO as for that price you get a proper ssd from one of the few flash manufactures left :moneybag:
Next best thing with SD cards is oversizing to have as many “fresh” cells available as possible which really leads to longer endurance (with the same amounts of writes) :bulb:
Thanks to all who answered.
My question is how do I format a SD Card that was used in a Pi5 for Home Assistant. I wouldn’t mind to replace a broken card with a new one. The card was working, the update failed.
If I used an SSD for the same application and I can’t format the SSD the damage to my walet would be bigger.
If you can’t even format the old card it’s probably grid locked (read only) which indicates EOL :headstone:
I replaced the card and I bought a spare card. You never know… but when you’re ready you not gonna need it :wink:
You might sharing make, model, class and size? :thinking:
Fingers crossed you didn’t went for a “endurance” (instead of class A) type falsely advertised before by @robertklep :crossed_fingers:
I have the SanDisk Ultra Class10, UHS-1, 32GB. SanDisk sell them here in Thailand normally for 8 USD.
SanDisk (now owned by western digital) is a well known brand and one of the few last flash manufacturers (like Samsung).
Dir you managed to get a A1 or A2 to class card which should offer best performance for I/I intensive tasks (what happens when running HaOS)?
32GB seems like the smallest available size today, often you get the double (64GB) for only one or two bucks more - which would be definitely worth it as it might just double the lifetime as explained earlier :rocket:
