Pi 5 second SD card bricked
That “endurance” (or durable) type cards are the wrong ones for this use case. :warning:
Do you mistake them for (expensive) “industrial” ones by chance? :thinking:
The best, when using SD cards, is (like the ha docs tell us) to use A1/A2 type cards.
Micro SD Card.
  • Ideally get one that is Application Class 2. Check for the label A2 on the card. Application Class 2 cards perform better especially on small read and write operations and are better suited to host applications.
  • Make sure to use a card that provides at least 32 GB.
The industrial type doesn’t make sense IMHO as for that price you get a proper ssd from one of the few flash manufactures left :moneybag:
Next best thing with SD cards is oversizing to have as many “fresh” cells available as possible which really leads to longer endurance (with the same amounts of writes) :bulb:
