Pi.Alert: Device Monitoring/ IP address inventory tool
I would like to share a little gem I have recently discovered on GitHub. As soon as I started developing my own ESPHome devices, I realized that my IPv4 home range was getting messy, and keeping up with the changes was becoming challenging. Sadly, Home Assistant doesn’t have a built-in way of managing this. However, I have found a solution: Pi.Alert. It has been my best new friend lately.
You can find Pi.Alert on GitHub at the following link:
Pi.Alert
Pi.Alert scans the devices connected to your WiFi/LAN and alerts you to the connection of unknown devices. It also provides warnings when an “always connected” device disconnects. Additionally, Pi.Alert offers the ability to check the availability of web services.
The setup process is well explained on the website, so I won’t repeat it here.
Pi.Alert provides a very basic API, and the author explains how to integrate it with Home Assistant. You can find instructions on how to do this in the following link:
Pi.Alert API Usage with Home Assistant
I hope someone will find this little piece of software as useful as I did.
Looks to be very handy.
Nice one! :wink: Thanks for sharing!
due the changes on 2023.6,
the way to define a command_lines sensor changed
This is the update sensor definition for PiAlert properties
command_line:
  - sensor:
      name: "PiAlert - Last Scan"
      command: curl -k -X POST -F 'api-key=--todo-api-key-here--' -F 'get=system-status' http://[mypialerthost]/pialert/api/
      scan_interval: 200
      unique_id: pialert.status.lastscan
      value_template: '{{ value_json.Last_Scan }}'
  - sensor:
      name: "PiAlert - All Devices"
      scan_interval: 200
      unique_id: pialert.status.alldevices
      unit_of_measurement: ""
      value_template: '{{ value_json.All_Devices }}'
  - sensor:
      name: "PiAlert - Online Devices"
      scan_interval: 200
      unique_id: pialert.status.onlinedevices
      value_template: '{{ value_json.Online_Devices }}'
  - sensor:
      name: "PiAlert - Offline Devices"
      scan_interval: 200
      unique_id: pialert.status.offlinedevices
      value_template: '{{ value_json.Offline_Devices }}'
  - sensor:
      name: "PiAlert - Archived Devices"
      scan_interval: 200
      unique_id: pialert.status.archiveddevices
      value_template: '{{ value_json.Archived_Devices }}'
  - sensor:
      name: "PiAlert - New Devices"
      scan_interval: 200
      unique_id: pialert.status.newdevices
      value_template: '{{ value_json.New_Devices }}'
  - sensor:
      name: "PiAlert - Scanning"
      scan_interval: 120
      unique_id: pialert.status.scanning
      value_template: '{{ value_json.Scanning }}'
Also mind that in my case, I had to add an “/pialert/” to the url as the api are not served from the root but from this secondary path
Hello, implement what is described here in my system and it works correctly, but I have a question, would it be possible to have more detailed information on the new devices, directly on HA, or failing that, at least be able to have some information for when detects a new device make an automation, for a notice… THANK YOU!
You will need to go to github (link in the first post) and raise that as a feature request.
Hey :wave:
I had a few people coming to my fork from this thread so just FYI there are 2 apps, leiweibau’s (linked in the first post) and mine, which I renamed to NetAlertX to avoid confusion. If interested my fork comes with more detailed device sync into home assistant via MQTT:
I like the GUI. I set up my subnets and I configured the ARP settings. On my network it quickly located the router and itself. Nothing else was found. I discovered that I needed to enable the ARP scan and then save the settings and it scanned. Still no other systems were found. Great GUI on the program, but I already know about my router and the Pi.Alert. Seems like a work in progress.
Update: I updated to NetAlertX and it seems about the same. I carefully configured my interface and the ARP. Looks like the issue is it doesn’t like running in a container despite being on the main LAN.
FWIW I ran both in a Proxmox container without issue. Decided to keep pialert. I’m not running any firewalls on Proxmox, however. ARP scan picks up everything in my single subnet.
Hey,
make sure you have the correct network interface specified and the container is running in --network=host. More info here:
I freshly installed Pi.Alert from this scipt: https://github.com/community-scripts/ProxmoxVE/raw/main/ct/pialert.sh.
It recognizes WAN and itself, but nothing else.
Scan Status indicates that no scan is running, the 5 minutes counts down and resets.
When I do an arp-scan in the shell all my devices are listed.
Is there anything else to set up?
# General Settings
PIALERT_PATH               = '/opt/pialert'
DB_PATH                    = PIALERT_PATH + '/db/pialert.db'
LOG_PATH                   = PIALERT_PATH + '/log'
PRINT_LOG                  = False
VENDORS_DB                 = '/usr/share/arp-scan/ieee-oui.txt'
PIALERT_APIKEY             = ''
PIALERT_WEB_PROTECTION     = False
PIALERT_WEB_PASSWORD       = '8d969eef6ecad3c29a3a629280e686cf0c3f5d5a86aff3ca12020c923adc6c92'
NETWORK_DNS_SERVER         = '10.0.0.112'
AUTO_UPDATE_CHECK          = True
AUTO_DB_BACKUP             = False
AUTO_DB_BACKUP_KEEP        = 5
REPORT_NEW_CONTINUOUS      = False
NEW_DEVICE_PRESET_EVENTS   = True
NEW_DEVICE_PRESET_DOWN     = False
SYSTEM_TIMEZONE            = 'Europe/Berlin'
OFFLINE_MODE               = False
# Other Modules
SCAN_WEBSERVICES           = True
ICMPSCAN_ACTIVE            = True
SATELLITES_ACTIVE = True
# Special Protocol Scanning
SCAN_ROGUE_DHCP            = False
DHCP_SERVER_ADDRESS        = '0.0.0.0'
# Custom Cronjobs
# The shortest interval is 3 minutes. All larger intervals must be integer multiples of 3 minutes.
AUTO_UPDATE_CHECK_CRON     = '0 3,9,15,21 * * *'
AUTO_DB_BACKUP_CRON        = '0 3 */2 * *'
REPORT_NEW_CONTINUOUS_CRON = '0 * * * *'
SPEEDTEST_TASK_CRON        = '00 7,22 * * *'
# Mail-Account Settings
SMTP_SERVER                = 'smtp.gmail.com'
SMTP_PORT                  = 587
SMTP_USER                  = '[email protected]'
SMTP_PASS                  = 'password'
SMTP_SKIP_TLS	           = False
SMTP_SKIP_LOGIN	           = False
# WebGUI Reporting
REPORT_WEBGUI              = True
REPORT_WEBGUI_WEBMON       = True
REPORT_TO_ARCHIVE          = 0
# Number of hours after which a report is moved to the archive. The value 0 disables the feature
# Mail Reporting
REPORT_MAIL                = False
REPORT_MAIL_WEBMON         = False
REPORT_FROM                = 'Pi.Alert <' + SMTP_USER + '>'
REPORT_TO                  = '[email protected]'
REPORT_DEVICE_URL          = 'http://pi.alert/deviceDetails.php?mac='
REPORT_DASHBOARD_URL       = 'http://pi.alert/'
# Pushsafer
REPORT_PUSHSAFER           = False
REPORT_PUSHSAFER_WEBMON    = False
PUSHSAFER_TOKEN            = 'ApiKey'
PUSHSAFER_DEVICE           = 'a'
PUSHSAFER_PRIO             = 0
PUSHSAFER_SOUND            = 22
# Pushover
REPORT_PUSHOVER            = False
REPORT_PUSHOVER_WEBMON     = False
PUSHOVER_TOKEN             = '<Token>'
PUSHOVER_USER              = '<User>'
PUSHOVER_PRIO              = 0
PUSHOVER_SOUND             = 'siren'
# NTFY
REPORT_NTFY                = False
REPORT_NTFY_WEBMON         = False
NTFY_HOST                  = 'https://ntfy.sh'
NTFY_TOPIC                 = 'replace_my_secure_topicname_91h889f28'
NTFY_USER                  = 'user'
NTFY_PASSWORD	           = 'password'
NTFY_PRIORITY 	           = 'default'
NTFY_CLICKABLE 	           = True
# Shoutrrr
SHOUTRRR_BINARY            = 'armhf'
# SHOUTRRR_BINARY            = 'armhf'
# SHOUTRRR_BINARY            = 'arm64'
# SHOUTRRR_BINARY            = 'x86'
# Telegram via Shoutrrr
REPORT_TELEGRAM            = False
REPORT_TELEGRAM_WEBMON     = False
TELEGRAM_BOT_TOKEN_URL     = '<Your generated servive URL for telegram - use $HOME/pialert/back/shoutrrr/<your Systemtyp>/shoutrrr generate telegram>'
# DynDNS and IP
QUERY_MYIP_SERVER          = 'https://myipv4.p1.opendns.com/get_my_ip'
DDNS_ACTIVE                = False
DDNS_DOMAIN                = 'your_domain.freeddns.org'
DDNS_USER                  = 'dynu_user'
DDNS_PASSWORD              = 'A0000000B0000000C0000000D0000000'
DDNS_UPDATE_URL            = 'https://api.dynu.com/nic/update?'
# Automatic Speedtest
SPEEDTEST_TASK_ACTIVE      = False
# Arp-scan Options & Samples
ARPSCAN_ACTIVE             = True
MAC_IGNORE_LIST            = []
IP_IGNORE_LIST             = []
SCAN_SUBNETS               = '--localnet'
# SCAN_SUBNETS               = '--localnet --interface=eth0'
# SCAN_SUBNETS               = ['192.168.1.0/24 --interface=eth0','192.168.2.0/24 --interface=eth1']
# ICMP Monitoring Options
ICMP_ONLINE_TEST           = 1
ICMP_GET_AVG_RTT           = 2
# Pi-hole Configuration
PIHOLE_ACTIVE              = False
PIHOLE_VERSION             = 5
PIHOLE_DB                  = '/etc/pihole/pihole-FTL.db'
PIHOLE6_URL                = ''
PIHOLE6_PASSWORD           = ''
PIHOLE6_API_MAXCLIENTS     = 100
DHCP_ACTIVE                = False
DHCP_LEASES                = '/etc/pihole/dhcp.leases'
DHCP_INCL_SELF_TO_LEASES   = False
# Fritzbox Configuration
FRITZBOX_ACTIVE            = False
FRITZBOX_IP                = '192.168.17.1'
FRITZBOX_USER              = 'user'
FRITZBOX_PASS              = 'password'
# Mikrotik Configuration
MIKROTIK_ACTIVE            = False
MIKROTIK_IP                = '10.0.0.1'
MIKROTIK_USER              = 'user'
MIKROTIK_PASS              = 'password'
# UniFi Configuration
UNIFI_ACTIVE               = False
UNIFI_IP                   = '10.0.0.2'
UNIFI_API                  = 'v5'
UNIFI_USER                 = 'user'
UNIFI_PASS                 = 'password'
# Possible UNIFI APIs are v4, v5, unifiOS, UDMP-unifiOS, default
# OpenWRT Configuration
OPENWRT_ACTIVE            = False
OPENWRT_IP                = '192.168.1.1'
OPENWRT_USER              = 'root'
OPENWRT_PASS              = ''
# Satellite Configuration
SATELLITE_PROXY_MODE       = False
SATELLITE_PROXY_URL        = ''
# Maintenance Tasks Cron
DAYS_TO_KEEP_ONLINEHISTORY = 60
DAYS_TO_KEEP_EVENTS        = 180
For who’s interested:
Instead of the curl command_line sensor which didn’t work for me in docker, I get the pialert.status in HA using the following configuration under sensor:
- platform: rest
  name: "PiAlert - Status"
  resource: "http://192.168.x.y/pialert/api/"
  method: POST
  headers:
    Content-Type: "application/x-www-form-urlencoded"
  payload: "api-key=[API-key]&get=system-status"
  json_attributes:
    - Last_Scan
    - All_Devices
    - Online_Devices
    - Offline_Devices
    - New_Devices
    - Down_Devices
    - Scanning
    - Offline_Devices_ICMP
    - Online_Devices_ICMP
  value_template: "{{ value_json.Last_Scan }}"
  scan_interval: 200
Installing from Home Assistant, I see that it says after first5 run, it will create data/db and data/config. Mine doesn’t appear to based on the log, no matter how many times I attampt to start it, whick means despite the UI button appearing, I can’t get in because it never really starts. This has to be something dumb. I’m running HASS inside a VM container on Proxmox. This is what the log gives me.
find: /data/db: No such file or directory
find: /tmp/api: No such file or directory
find: /tmp/log: No such file or directory
find: /tmp/run: No such file or directory
find: /data/config: No such file or directory
find: /data/config/app.conf: No such file or directory
find: /data/db/app.db: No such file or directory
Permissions fixed for read-write paths. Please restart the container as user 20211.
