I’m having some issues with the all-in-one installer - the process ends with:
File "/usr/local/lib/python2.7/dist-packages/fabric/main.py", line 666, in main
docstring, callables, default = load_fabfile(fabfile)
File "/usr/local/lib/python2.7/dist-packages/fabric/main.py", line 167, in load_fabfile
imported = importer(os.path.splitext(fabfile)[0])
File "/home/pi/fabric-home-assistant/fabfile.py", line 177
fabric.contrib.files.append("/home/hass/.homeassistant/configuration.yaml", hacfg, use_sudo=True)
SyntaxError: invalid syntax```
This is on a fresh, updated Raspian Jessie on a RaspberryPi 2 B+.
Any thoughts/help appreciated :slight_smile:
