Awesome thank you so much!
It is possible to use text to speech (tts) too? Using the audio jack output
I have installed the add-on, and I can call the function in my browser but can’t seem to make this work in Hassio, I have tried your start notification, but it just gives me errors, also you didn’t say whether it went into the configuration yaml or automation yaml.
hello there @Andy_Nunes, well, you can place the service wherever you need it… and the startup notification it’s in automations.yaml.
I updated my Hass.io to the latest release and it still works, so it should work on yours too.
This is how my addon looks like in my Hassio section:
Is it the same on yours?
oh wait… on my hassio is installed locally, let me install the one on github and see if it still works…
Actually you’re right, it works if the addon is local, but doesn’t work if installed using the repository.
I’ll try to understand why, meanwhile you can follow these instructions:
to make it work on your system.
ok, I found out where is the problem.
If you create the addon locally then you have to use the command addon: local_audio_player, like
- service: hassio.addon_stdin
input: "http://192.168.1.100:8123/local/song.mp3"
but if you install it from the repository, you’ll have to modify the line replacing “local” with the number you see in the url:
so, in this case it will be:
addon: de3cd379_audio_player
Okay that works fine, but I still can’t get any audio playback via the pi this is what is in the log :
starting version 3.2.4
starting!
[Info] Read alias: https://my.duckdns.org/local/MrDJ.mp3
play WARN alsa: can’t encode 0-bit Unknown or not applicable
wget: error getting response: Connection reset by peer
play FAIL formats: can’t open input file URL `https://my.duckdns.org/local/MrDJ.mp3’:
[Error] Playing failed →
Any ideas?
I am also getting this error in main log:
Log Details (WARNING)
Thu Feb 08 2018 12:55:38 GMT+0000 (GMT)
Unable to find service hassio/addon_stdin
Try using the internal ip like:
http://192.168.1.100:8123/local/MrDJ.mp3
Or changing the mp3 file and tell me if something changes.
This is what you should see in the addon log:
[Info] Read alias: http://192.168.1.100:8123/local/power_down.mp3
play WARN alsa: can't encode 0-bit Unknown or not applicable
http://192.168.1.100:8123/local/power_down.mp3:
File Size: 0
Encoding: MPEG audio
Channels: 2 @ 16-bit
Samplerate: 48000Hz
Replaygain: off
Duration: unknown
In:0.00% 00:00:00.00 [00:00:00.00] Out:0 [ | ] Clip:0
In:0.00% 00:00:00.51 [00:00:00.00] Out:20.5k [ | ] Clip:0
In:0.00% 00:00:00.60 [00:00:00.00] Out:28.7k [ | ] Clip:0
In:0.00% 00:00:00.77 [00:00:00.00] Out:36.9k [ | ] Clip:0
In:0.00% 00:00:00.94 [00:00:00.00] Out:45.1k [ | ] Clip:0
In:0.00% 00:00:01.11 [00:00:00.00] Out:53.2k [ | ] Clip:0
In:0.00% 00:00:01.28 [00:00:00.00] Out:61.4k [ | ] Clip:0
In:0.00% 00:00:01.37 [00:00:00.00] Out:65.5k [ | ] Clip:0
In:0.00% 00:00:01.54 [00:00:00.00] Out:73.7k [ | ] Clip:0
In:0.00% 00:00:01.71 [00:00:00.00] Out:81.9k [ | ] Clip:0
In:0.00% 00:00:01.73 [00:00:00.00] Out:82.9k [ | ] Clip:0
Done.
Still no joy changed IP, changed MP3 but still get the same errors.
I think my problem with this may stem from using SSL
Can this also be a streaming mp3 file?
Apparently yes, I just made this script:
local_radio:
input: "http://icestreaming.rai.it/1.mp3"
…and it works. So, yes, you can stream your favourite radios directly on the raspberry pi 3.5mm audio jack
Hello Pantomax, very new to this Hassio system but im begining to like it, but as a noob I’m having problems with testing json service call in developer module. Basically I would like to trigger a sound when temperature of sensor reaches a certain level but being a noob and an old git can’t get this to work. Is it possible to use the call service and test json format. If it’s possible could you give us an example please?
Hey @OldGitHub,
actually I don’t really know how to answer to your question, I’m not even a coder, so my knowledge level is very low. Maybe… something like:
"addon" : "de3cd379_audio_player",
"input" : "http://192.168.1.100:8123/local/sound_when_temperature_of_sensor_reaches_a_certain_level.mp3"
Hello again @Pantomax…you sir are a legend, brilliant, I made the error of missing “input”, which was why I kept getting errors in the log…Doh! this is great, after pulling out what hair I had left, I can now wire the house up with sensors and speakers, the only down-fall is I’m probably gonna get an ear bashing from TheOldGirl when a trigger sounds an alert. This home automation stuff is brill…thanks again for your quick reply
Glad that I could help.
Happy automating over there, let your home sound like the USS Enterprise computer
