Pi-CPU-temp drops like a rock
So I decided to change the Pi-cpu-temp unit to imperial from celcius. My system is set to celcius but I just wanted the cpu temp in Fahrenheit. When I check the graph of the cpu temp, however, it appeared to have dropped.
cpu_temp
The temp is currently showing 2.2 degrees C. which is impossible. The Pi feels just warm to the touch. I decided to change everything back to Celcius including the cpu-temp customization, the setting in General and the sensor entity for cpu-temp but nothing worked. Any ideas about what would cause this and how to get it back would be helpful. thanks
This is an Argon setup Rpi4 with SSD. HAos all up to date.
