Pi-hole integration is not working for me at all. I have a Pi-hole at a fixed IP, no problems with it running. When I try and add the Pi-hole to Home Assistant. It looks like it worked, without even prompting for my password, but all entities are unresponsive (Unknown). I have tried this with a newly spun up pi-hole on a different devices and I see the same thing. I am running home assistant OS using the community script for a proxmox install. Any ideas what I can do to make sure I get prompted for a password and therefore allow me to authorise the connection. At some point in the past, I had Pi-hole connected, but I changed the pihole instance so tried to reconfigure a new connection from home assistant.
Pi-hole version 6 and later uses a new API that is currently not supported by Home Assistantās built in integration.
There is an integration in HACS that works with the newer Pi-hole API.
Thereās also notes in the current beta that the built in integration will gain support for the new API in the 2025.8 release of Home Assistant.
As said above if using HACS Pi-hole V6 Integration for Home Assistant works quite well with Pi-hole v.6x.
Completing the above with Pi-hole Card gives you a nice dashboard card for managing and monitoring your Pi-hole.
I think that was just updatedā¦
The integration is working vor v6 starting with HA Core 2025.8. But as with the old v5 api, changes on the Pi-Hole side are not updated fast enough in Home Assistant:
When I disable/enable Pi-Hole from outside HA, it often takes minutes (!) for the change to get reflected in HA.
For this as a workaround in the past I had this CL sensor:
command_line:
- sensor:
unique_id: xxx
scan_interval: 10
command: curl -X GET 'http://xxx.xxx.xxx.xxx/admin/api.php?status&auth=API-KEY'
value_template: >
{{ value_json.status }}
Now with v6 API and the need for a session ID in combination with running that CL sensor every 10 seconds this creates a lot new session ids, reaching Pi-Hole`s āmax_sessionsā limit (default: 16).
I tried many many MANY ways to continue using this workaround (CL sensor) with the new v6 API, but it does not work.
So the core question is:
Why does it take so long for HA to discover changes? Is the polling that slowly? Really, it must be something like 4 to 5 minutes!
(edit: it is 5 minutes. hard coded default polling interval. fine for statistics, bad for switch status.)
