Pi hole sensor config error
Sure its me, but what is wrong with my code here:
pi_hole:
  - host: '192.168.1.117:4865'
I get this error which I do not understand:
Invalid config for [pi_hole]: expected a dictionary for dictionary value @ data[‘pi_hole’]. Got [OrderedDict([(‘host’, ‘192.168.1.117:4865’)])]. (See /config/configuration.yaml, line 85). Please check the docs at https://home-assistant.io/integrations/pi_hole/
I am running Pi Hole Hassio Addon on my Pi which has that IP address?
Thanks!
This is my config and it works ok I am not sure that you need the port number on the end either:
pi_hole:
  - host: '192.168.0.4'
    ssl: False
    verify_ssl: False
Thanks will try that. The docs say you need port if using the hassio addon but will try.
Are you using the addon?
Hmm just using the pi_hole and ip lines doesn’t work either.
I wonder if it’s because I am on duckdns and have duckdns set in the pi hole config as server?
IP addresses work. Hostnames should work, as long as your local DNS works. You only need the port number if it is non standard (as with the addon).
You error message implies some sort of formatting error in your yaml. Make sure it is indented correctly, including no tabs.
It may be the : before the port number. Try either no quoting or " quoting.
No I am not using the addon sorry I don’t have any other suggestions.
Thinking about it I am sure I got that error before I added:
Try without the port and check the indentation.
ok So I have tried these options. I have included the full config file down to the pi_hole part as it advises to add Pi_hole at the top, not within sensors etc. Assuming where I have put it is ok
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
  customize: !include customize.yaml
pi_hole:
  - host: '192.168.1.117'
the above gives this error:
Invalid config for [pi_hole]: expected a dictionary for dictionary value @ data[‘pi_hole’]. Got [OrderedDict([(‘host’, ‘192.168.1.117’)])]. (See /config/configuration.yaml, line 8). Please check the docs at https://home-assistant.io/integrations/pi_hole/
Then I tried with port:
default_config:
homeassistant:
pi_hole:
which gives pretty much the same error:
Invalid config for [pi_hole]: expected a dictionary for dictionary value @ data[‘pi_hole’]. Got [OrderedDict([(‘host’, ‘192.168.1.117:4865’)])]. (See /config/configuration.yaml, line 8). Please check the docs at https://home-assistant.io/integrations/pi_hole/
Then I took quotes out:
default_config:
homeassistant:
pi_hole:
  - host: 192.168.1.117:4865
and still got the error:
So then I took port out:
default_config:
homeassistant:
pi_hole:
and got this:
Trying the code posted by @daveyrb I used this:
pi_hole:
    ssl: False
    verify_ssl: False
and got this error:
Invalid config for [pi_hole]: expected a dictionary for dictionary value @ data[‘pi_hole’]. Got [OrderedDict([(‘host’, ‘192.168.1.117’), (‘name’, ‘HomePiHole’), (‘ssl’, False), (‘verify_ssl’, False)])]. (See /config/configuration.yaml, line 8). Please check the docs at https://home-assistant.io/integrations/pi_hole/
So its really not happy.
Keep thinking I must be using the wrong location to type it or wrong docs
So I added this:
default_config:
homeassistant:
pi_hole:
  host: 192.168.1.117
And now I can see all the sensors. they show as unavailable though, so maybe they were there pre adding anything to the config?
Think I need to give up on this.
ok!
Perseverance is the key, docs are wrong, this works:
pi_hole:
  host: "192.168.1.117:4865"
  ssl: false
  verify_ssl: false
Matt,
Just to check what version of HA are you running? As the Pi-Hole integration did have a breaking change (I think in release 103 might have been 102)
