Hi Guys,
i’m running pi- hole on a dedicated ubuntu server, (virtual box).
i’m wondering how can i retrieve cpu & memory, ip address,disk space etc and display on hassio.
Any ideas how can i achieve it?
Hi Guys,
SSH sensor from HACS or here:
You should be able to get all that info from SNMP also
or glances
Thank you,
- platform: snmp
host: 192.168.0.160
baseoid: 1.3.6.1.4.1.2021.10.1.3.1
something else that i need to do?
i cant see anything
You restarted and looked in the dev-states page?
Have you verified the OID is correct with an SNMPWalk?
Have you added it to your front end?
this what i see in the log file after reboot
019-08-01 21:29:10 ERROR (MainThread) [homeassistant.components.snmp.sensor] Please check the details in the configuration file`Preformatted text
Have you verified the OID is correct with an SNMPWalk? how?
Have you added it to your front end? how?
do i need to install something on the ubuntu server?
You need snmpd installed and configured. SNMP isn’t magic…it does need to connect to a listening service.
Based on:
This means that the sensor wasn’t added, and you can’t add it to your frontend.
