I am able to boot a Pi Zero W 2 using Pi imager and Raspbian OS 32 bit. However I am unable to boot up using version haos_rpi0-w-6.6.img. The same image works great on a Pi Zero W. I have connected a monitor to the system and do not see any boot up messages.
I realize the unit is brand new. I hope you are already working with one.
Sorry that did not work. I think it is something in the boot code. When the current Raspbian is on the SD card you get a bit of flickering after a solid flash followed by the led being off for 1 or 2 seconds. When HA image is on the SD just a solid green led. Maybe they need some sort of firmware update.
It’s brand new and I don’t think Raspberry Pi doesn’t test something like HA and leave it up to them to find these kinds of bugs.
I just joined to say this looks universal. I bought a Pi Zero 2 W to take over a very small setup I’ve been running on a VM for the past year or so. None of the HAOS installations work - blank screen.
I have no such problems running RaspOS
I was able load the version of HA that has no supervisor by installing the 32 bit OS using Raspberry Imager and doing a apt-get full-upgrade. Then I installed dozer and then HA. Used the following commands:
curl -fsSL https://get.docker.com -o get-docker.sh
sudo sh get-docker.sh
docker -v
Docker version 20.10.10, build b485636
