Pi Zero W Dashbard
Hi, I am struggling with a seemingly simple problem.
I would like to create a dashboard using a pc monitor and Raspberry Pi Zero W to display some sensor values and gauges, but I cannot get it to work.
I’ve installed Buster 32 bit on the pi and tried to use chromium, firefox and midori to display the Lovelace dashboard, but it seems that the pi is too slow to render the dashboard and just logging in takes forever.
I know that the pi should be powerful enough to be used for displaying a dashboard, but I’m not sure how to get it working.
Has anybody done this successfully?
I managed using the fullpageos but found it was very slow to load and you need to keep the dashboard super simple
Yes, I also tried that, but it is veeeery slow.
At the moment I’m looking at tileboard, but I’m not sure I would be able to get it up and running.
