Hello again,
after running flawlessly for a few weeks in pretty much the same spot (hidden above the ceiling) my rapsberry pi 3 with hassbian started to hang more and more often. It did so yesterday before I went to bed, I unplugged and plugged it back to restart, and a few hours later when i woke up and tried to turn on some lights I saw that hass was not accessible anymore, neither was my pi through SSH, so it hanged up on me again.
Any common reasons for that? Might it be that it’s running at around 59-60 degrees celsius? I could put a fan next to it, and it would stay at around 45 degrees, but I see that people say that it should work with temps up to 85-90 without problems. And fans are noisy.
So, if anyone has any ideas of at least where to start looking for problems - would be a lot of help. Thanks.
Hassbian with zwave on raspberry pi 3.
UPDATE:
Checked logs, and the only thing I found there, since they are overwritten during restart, was [homeassistant.components.recorder] Ended unfinished session
After that I read about it, and noticed that by default it’s using SQLite, which I know is not ideal for large databases. And the database file is about 130Mb right now. Can this be the problem? Did my database get too big? Should I setup purging? Not sure that I need to run mysql on pi
