Pi3B+ setup with Razberry V2
Hi all,
i have a big Problem with the Razberry V2 and a Raspberry Pi3 B+
My Test´s:
Edit the boot/config:
enable_uart=1
dtoverlay=pi3-miniuart-bt
and this:
dtoverlay=disable-bt
enable_uart=1
HA Infos:
# deCONZ
/dev/ttyAMA0     | 0x0000 | 0x0000  |            | RaspBee
/dev/ttyACM0     | 0x1CF1 | 0x0030  |            | ConBee II
serial:
- /dev/ttyAMA0
- /dev/ttyS0
- /dev/ttyACM0
- /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2408889-if00
Btw. the USB ConBee2 works perfect.
My configuration.yaml Test´s:
## MultiSensoring
zwave:
  #device: /dev/ttyAMA0
  usb_path: /dev/ttyAMA0
  #usb_path: /dev/ttyS0
  network_key: 0xxx, 0xxx, ....
  debug: true
On the Chip the light dont up green. Only at the “Restart” from Pi3 there short light up green…
Configuration -> Integrations -> Z-Wave:
network_key: >-
  0xxx, 0xxx, ....
instance: 1
After i start the OpenZWave Web.
I can Do this:
Connected to Qt for Embedded Linux VNC Server
Select the ttyAMA0
i press the “Start” Button, and then he Disconnected
OZW_Log.txt:
2021-01-05 16:50:05.218 Always, OpenZwave Version 1.4.3469 Starting Up
2021-01-05 16:50:48.766 Info, Setting Up Provided Network Key for Secure Communications
2021-01-05 16:50:48.799 Info, mgr,     Added driver for controller /dev/ttyAMA0
2021-01-05 16:50:48.800 Info,   Opening controller /dev/ttyAMA0
2021-01-05 16:50:48.800 Info, Trying to open serial port /dev/ttyAMA0 (attempt 1)
2021-01-05 16:50:48.801 Info, Serial port /dev/ttyAMA0 opened (attempt 1)
2021-01-05 16:50:48.802 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-05 16:50:48.802 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2021-01-05 16:50:48.803 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2021-01-05 16:50:48.803 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2021-01-05 16:50:48.803 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2021-01-05 16:50:48.803 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2021-01-05 16:50:48.927 Detail, contrlr,   Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x36, 0x2e, 0x30, 0x32, 0x76, 0x65, 0x20
2021-01-05 16:50:48.928 Warning, contrlr, WARNING: Checksum incorrect - sending NAK
2021-01-05 16:50:49.430 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2021-01-05 16:50:49.945 Warning, WARNING: 500ms passed without reading the rest of the frame...aborting frame read
2021-01-05 16:50:50.189 Warning, WARNING: Out of frame flow! (0x5a).  Sending NAK.
2021-01-05 16:50:58.803 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2021-01-05 16:50:58.810 Detail, contrlr, Removing current message
2021-01-05 16:50:58.810 Detail, contrlr, Notification: Notification - TimeOut
2021-01-05 16:50:58.829 Detail,
2021-01-05 16:50:58.829 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2021-01-05 16:50:58.833 Detail, contrlr,   Received: 0x01, 0x08, 0x01, 0x20, 0xdb, 0xd6, 0x82, 0xde, 0x01, 0x86
2021-01-05 16:50:58.834 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xdbd682de.  Our node ID = 1
2021-01-05 16:50:58.834 Detail, Node214,   Expected reply was received
2021-01-05 16:50:58.834 Detail, Node214,   Message transaction complete
2021-01-05 16:50:58.834 Detail, contrlr, Removing current message
2021-01-05 16:50:58.835 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2021-01-05 16:50:58.839 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2021-01-05 16:50:58.839 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2021-01-05 16:50:58.839 Info, contrlr,     There is no SUC ID Server (SIS) in this network.
2021-01-05 16:50:58.839 Info, contrlr,     The PC controller is a primary controller.
2021-01-05 16:50:58.839 Detail, Node215,   Expected reply was received
2021-01-05 16:50:58.839 Detail, Node215,   Message transaction complete
2021-01-05 16:50:58.840 Detail,
2021-01-05 16:50:58.840 Detail, contrlr, Removing current message
2021-01-05 16:50:58.840 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2021-01-05 16:50:58.846 Detail, contrlr,   Received: 0x01, 0x2b, 0x01, 0x07, 0x05, 0x25, 0x01, 0x47, 0x04, 0x00, 0x00, 0x02, 0xfe, 0x87, 0x7f, 0x88, 0xcf, 0x3f, 0xc0, 0x47, 0xfb, 0xdf, 0xfd, 0xe0, 0x67, 0x00, 0x80, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x80, 0x0f, 0x00, 0x00, 0x60, 0xda, 0x00, 0xbd
2021-01-05 16:50:58.847 Detail,
2021-01-05 16:50:58.847 Info, contrlr,  Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2021-01-05 16:50:58.847 Info, contrlr,     Serial API Version:   5.37
2021-01-05 16:50:58.848 Info, contrlr,     Manufacturer ID:      0x0147
2021-01-05 16:50:58.848 Info, contrlr,     Product Type:         0x0400
2021-01-05 16:50:58.848 Info, contrlr,     Product ID:           0x0002
2021-01-05 16:50:58.848 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2021-01-05 16:50:58.848 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2021-01-05 16:50:58.850 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2021-01-05 16:50:58.851 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2021-01-05 16:50:58.852 Detail, Node037,   Expected reply was received
2021-01-05 16:50:58.861 Detail, Node037,   Message transaction complete
2021-01-05 16:50:58.862 Detail,
2021-01-05 16:50:58.862 Detail, contrlr, Removing current message
2021-01-05 16:50:58.862 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2021-01-05 16:50:58.864 Detail, contrlr,   Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2021-01-05 16:50:58.865 Detail,
2021-01-05 16:50:58.865 Info, contrlr, Received reply to GET_SUC_NODE_ID.  Node ID = 0
2021-01-05 16:50:58.865 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2021-01-05 16:50:58.865 Detail, Node172,   Expected reply was received
2021-01-05 16:50:58.866 Detail, Node172,   Message transaction complete
2021-01-05 16:50:58.866 Detail, contrlr, Removing current message
2021-01-05 16:50:58.866 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2021-01-05 16:50:58.921 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0x87, 0xb5, 0x9a, 0x53, 0x45, 0x45, 0x18, 0x2b, 0xe2, 0x2d, 0x6d, 0x49, 0x47, 0xcf, 0x13, 0xb0, 0x7d, 0x57, 0xdc, 0xa6, 0x0e, 0xc2, 0x55, 0x97, 0x6d, 0x87, 0xd3, 0xd2, 0x31, 0x4d, 0x3e, 0x79, 0x60
2021-01-05 16:50:58.921 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2021-01-05 16:50:58.921 Detail, Node032,   Expected reply was received
2021-01-05 16:50:58.921 Detail, Node032,   Message transaction complete
2021-01-05 16:50:58.921 Detail, contrlr, Removing current message
2021-01-05 16:50:58.921 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2021-01-05 16:50:58.982 Detail, contrlr,   Received: 0x01, 0x25, 0x01, 0x02, 0x06, 0x00, 0x1d, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc6
2021-01-05 16:50:58.983 Detail,
2021-01-05 16:50:58.983 Info, mgr,     Driver with Home ID of 0xdbd682de is now ready.
2021-01-05 16:50:58.984 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2021-01-05 16:50:58.984 Info, contrlr,     Node 001 - New
2021-01-05 16:50:58.985 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=None live=1
2021-01-05 16:50:58.985 Detail, Node001, QueryStage_ProtocolInfo
2021-01-05 16:50:58.985 Detail, Node001, Queuing (Query) Get Node Protocol Info (Node=1): 0x01, 0x04, 0x00, 0x41, 0x01, 0xbb
2021-01-05 16:50:58.985 Detail, Node001, Queuing (Query) Query Stage Complete (ProtocolInfo)
2021-01-05 16:50:58.985 Info, Node001, Initializing Node. New Node: false (false)
2021-01-05 16:50:58.986 Detail,   Expected reply was received
2021-01-05 16:50:58.986 Detail,   Message transaction complete
2021-01-05 16:50:58.986 Detail, contrlr, Removing current message
2021-01-05 16:50:58.986 Detail, Node001, Notification: DriverReady
2021-01-05 16:50:58.989 Detail, Node001, Notification: NodeNew
2021-01-05 16:50:58.990 Detail, Node001, Notification: NodeAdded
2021-01-05 16:50:59.091 Detail,
2021-01-05 16:50:59.121 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2021-01-05 16:50:59.125 Detail, contrlr,   Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2021-01-05 16:50:59.127 Detail,
2021-01-05 16:50:59.127 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2021-01-05 16:50:59.127 Detail, Node015,   Expected reply was received
2021-01-05 16:50:59.128 Detail, Node015,   Message transaction complete
2021-01-05 16:50:59.128 Detail, contrlr, Removing current message
2021-01-05 16:50:59.128 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2021-01-05 16:50:59.131 Detail, contrlr, Removing current message
2021-01-05 16:50:59.132 Detail,
2021-01-05 16:50:59.132 Info, Node001, Sending (Query) message (Callback ID=0x00, Expected Reply=0x41) - Get Node Protocol Info (Node=1): 0x01, 0x04, 0x00, 0x41, 0x01, 0xbb
2021-01-05 16:50:59.142 Detail, Node001,   Received: 0x01, 0x09, 0x01, 0x41, 0xd3, 0x16, 0x01, 0x02, 0x02, 0x01, 0x73
2021-01-05 16:50:59.143 Detail,
2021-01-05 16:50:59.143 Info, Node001, Received reply to FUNC_ID_ZW_GET_NODE_PROTOCOL_INFO
2021-01-05 16:50:59.143 Info, Node001,   Protocol Info for Node 1:
2021-01-05 16:50:59.143 Info, Node001,     Listening     = true
2021-01-05 16:50:59.144 Info, Node001,     Beaming       = true
2021-01-05 16:50:59.145 Info, Node001,     Routing       = true
2021-01-05 16:50:59.146 Info, Node001,     Max Baud Rate = 40000
2021-01-05 16:50:59.146 Info, Node001,     Version       = 4
2021-01-05 16:50:59.147 Info, Node001,     Security      = false
2021-01-05 16:50:59.184 Info, Node001,   Basic device class    (0x02) - Static Controller
2021-01-05 16:50:59.184 Info, Node001,   Generic device Class  (0x02) - Static Controller
2021-01-05 16:50:59.185 Info, Node001,   Specific device class (0x01) - Static PC Controller
2021-01-05 16:50:59.185 Info, Node001,     COMMAND_CLASS_BASIC is not mapped
2021-01-05 16:50:59.185 Info, Node001,   Mandatory Command Classes for Node 1:
2021-01-05 16:50:59.185 Info, Node001,     None
2021-01-05 16:50:59.185 Info, Node001,   Mandatory Command Classes controlled by Node 1:
2021-01-05 16:50:59.185 Detail, Node022,   Expected reply was received
2021-01-05 16:50:59.185 Detail, Node022,   Message transaction complete
2021-01-05 16:50:59.185 Detail, Node001, Removing current message
2021-01-05 16:50:59.185 Detail, Node001, Notification: NodeProtocolInfo
2021-01-05 16:50:59.189 Detail, Node001, Notification: ValueAdded
2021-01-05 16:50:59.366 Warning, Exception: Manager.cpp:2499 - 102 - ValueID passed to GetValueFloatPrecision is not a Decimal Value
2021-01-05 16:50:59.376 Detail, Node001, Query Stage Complete (ProtocolInfo)
2021-01-05 16:50:59.376 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Probe live=1
2021-01-05 16:50:59.376 Detail, Node001, QueryStage_Probe
2021-01-05 16:50:59.376 Detail, Node001, QueryStage_WakeUp
2021-01-05 16:50:59.376 Detail, Node001, QueryStage_ManufacturerSpecific1
2021-01-05 16:50:59.376 Detail, Node001, Load Controller Manufacturer Specific Config
2021-01-05 16:50:59.447 Info, Product name collision: FGR223 Roller Shutter Controller 3 type 303 id 1000 manufacturerid 10f, collides with FGRM223 Roller Shutter Controller 3, type 303 id 1000 manufacturerid 10f
2021-01-05 16:50:59.458 Detail, Node001, QueryStage_NodePlusInfo
2021-01-05 16:50:59.459 Detail, Node001, QueryStage_SecurityReport
2021-01-05 16:50:59.459 Detail, Node001, QueryStage_ManufacturerSpecific2
2021-01-05 16:50:59.459 Detail, Node001, QueryStage_Versions
2021-01-05 16:50:59.459 Detail, Node001, QueryStage_Instances
2021-01-05 16:50:59.459 Info, Node001, Essential node queries are complete
2021-01-05 16:50:59.459 Detail, Node001, QueryStage_Static
2021-01-05 16:50:59.459 Detail, Node001, QueryStage_Associations
2021-01-05 16:50:59.459 Detail, Node001, QueryStage_Neighbors
2021-01-05 16:50:59.459 Detail, Requesting routing info (neighbor list) for Node 1
2021-01-05 16:50:59.459 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2021-01-05 16:50:59.459 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2021-01-05 16:50:59.459 Detail, Node001, Notification: EssentialNodeQueriesComplete
2021-01-05 16:50:59.482 Detail,
2021-01-05 16:50:59.482 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2021-01-05 16:50:59.488 Detail, Node001,   Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2021-01-05 16:50:59.489 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2021-01-05 16:50:59.489 Info, Node001,     Neighbors of this node are:
2021-01-05 16:50:59.489 Info, Node001,  (none reported)
2021-01-05 16:50:59.489 Detail,   Expected reply was received
2021-01-05 16:50:59.489 Detail,   Message transaction complete
2021-01-05 16:50:59.489 Detail, Node001, Removing current message
2021-01-05 16:50:59.489 Detail, Node001, Query Stage Complete (Neighbors)
2021-01-05 16:50:59.489 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2021-01-05 16:50:59.489 Detail, Node001, QueryStage_Session
2021-01-05 16:50:59.489 Detail, Node001, QueryStage_Dynamic
2021-01-05 16:50:59.490 Detail, Node001, QueryStage_Configuration
2021-01-05 16:50:59.490 Detail, Node001, QueryStage_Complete
2021-01-05 16:50:59.498 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2021-01-05 16:50:59.498 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2021-01-05 16:50:59.499 Info,          Node query processing complete.
2021-01-05 16:50:59.499 Detail, Node001, Notification: NodeQueriesComplete
2021-01-05 16:50:59.511 Detail, contrlr, Notification: AllNodesQueried
2021-01-05 16:52:06.656 Detail,   Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2021-01-05 16:52:06.692 Detail,
2021-01-05 16:52:06.692 Info, Received reply to GET_SUC_NODE_ID.  Node ID = 0
2021-01-05 16:52:06.769 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
What can i Do ? for the Raspberry Pi3 B+ ?
Thanks for Help!
You shouldn’t use the top part of the OZW application, just the lower half (Remote Daemon) and just click start. Then it shouldn’t crash as 2 applications can’t use the same serial port.
@RickKramer OMG it works :smiley:
and now i see that:
and the integrations:
ozw-config-1
But on the chip the light is not green?
Is the Chip correctly connected? i am on the right serial-port ?
i have now 2 zwave?
what is the difference “OpenZWave (beta)” vs “Z-Wave”?
ozw-integrations ozw-integrations-2
important info, only usw one z-wave Plugin!
i use now only OpenZWave (beta) and delete now z-wave.
now it works perfekt, and i add the new Node => Aeotec MultiSensor 6 :star_struck:
Thanks for help
