I’m hoping this was posted in the right spot… I didn’t see it in the categories now that I’m at home (was published from my phone while on the road).
Here is the config.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: (link redacted for new user limit)
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
##This version of the holiday lights code does not require the node red portion
##The "W" slider under the main "holiday LED" light modifies each effect
##The "W" slider under "Glitter" light modifies the frequency of glitter, the RGB selection changes the color of the glitter
##The "W" slider under "Lightning" switch modifies the frequency of lightning.
##You must replace the [MQTT_CLIENT_ID] with the USER_MQTT_CLIENT_NAME you specified in the arduino USER CONFIGURATION section
- platform: mqtt
state_topic: "[LightTest]/locator"
light:
- platform: mqtt
command_topic: "[LightTest]/power"
state_topic: "[LightTest]/powerState"
brightness_command_topic: "[LightTest]/brightness"
brightness_state_topic: "[LightTest]/brightnessState"
brightness_scale: 255
white_value_command_topic: "[LightTest]/modifier"
white_value_state_topic: "[LightTest]/modifierState"
white_value_scale: 500
effect_command_topic: "[LightTest]/effect"
effect_state_topic: "[LightTest]/effectState"
effect_list:
- Color_Chase
- Color_Glitter
- Single_Race
- Double_Crash
- Rainbow
- Blocked_Colors
- BPM
- Twinkle
- Fire
- Fill_Solid
- Spooky_Eyes
- LED_Locator
retain: true
- platform: mqtt
command_topic: "[LightTest]/ColorPower"
rgb_command_topic: "[LightTest]/color1"
rgb_state_topic: "[LightTest]/color1State"
retain: true
- platform: mqtt
rgb_command_topic: "[LightTest]/color2"
rgb_state_topic: "[LightTest]/color2State"
retain: true
- platform: mqtt
rgb_command_topic: "[LightTest]/color3"
rgb_state_topic: "[LightTest]/color3State"
retain: true
- platform: mqtt
state_topic: "[LightTest]/glitter/state"
command_topic: "[LightTest]/addEffects"
payload_on: "Glitter On"
payload_off: "Glitter Off"
rgb_command_topic: "[LightTest]/glitterColor"
rgb_state_topic: "[LightTest]/glitterColorState"
white_value_command_topic: "[LightTest]/glitterChance"
white_value_state_topic: "[LightTest]/glitterChanceState"
white_value_scale: 255
retain: true
- platform: mqtt
state_topic: "[LightTest]/lightning/state"
payload_on: "Lightning On"
payload_off: "Lightning Off"
white_value_command_topic: "[LightTest]/lightningChance"
white_value_state_topic: "[LightTest]/lightningChanceState"
retain: true
here is the groups.yaml:
LightTest:
entities:
- light.holiday_lights
- light.color_1
- light.color_2
- light.color_3
- light.glitter
- light.lightning
- sensor.current_led
here is the top of the ESP8266 code (username/password redacted):
#define USER_SSID "(redacted)"
#define USER_PASSWORD "(redacted)"
#define USER_MQTT_SERVER "192.168.1.149"
#define USER_MQTT_PORT 1883
#define USER_MQTT_USERNAME "Kristy_Thomas_MQTT"
#define USER_MQTT_PASSWORD "(redacted)"
#define USER_MQTT_CLIENT_NAME "LightTest" // Used to define MQTT topics, MQTT Client ID, and ArduinoOTA
Mosquito Broker configuration (password redacted):
"logins": [
"username": "Kristy_Thomas_MQTT",
"password": "(redacted)"
"anonymous": false,
"customize": {
"active": false,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"require_certificate": false
The summary shows it identifies the IP address/username above, however,there is NOTHING under:
Configuration - Devices
Configuration - Integration - Mosquito Broker (this integration has no devices)
The overview page only shows the local weather (even though I’ve updated the groups.yaml - and even tried to add a lighting by clicking the +, however that forced the pi to restart and nothing showed up)
