PI5 with NVMe - HA not running
I’ve installed the preview of HA on my PI 5 with NVME from NVMe Base for Raspberry Pi 5 - NVMe Base
It booted up fine and I could navigate to both the assistant URL and the observer URL.
The assistant URL said it was getting ready and would take around 20 mins but after a while this just stopped responding. The observer URL doesn’t show any issues.
I’m unsure where the logs are by default to pull additional info, but I’m happy to pull them.
Screenshots below.
Maybe find clues in
cat /config/home-assistant.log*
ha core logs
ha os info
ha core info
ha hardware info
Thanks, it looks like the core is crashing since /config doesnt exist and is a read only filesystem with various overlays
Why is / full? :man_shrugging:
That is how it was configured when using the rpi-imager and using the preview image for HA 11.5
Looks like all the bits you want writable are mounts, and the /config should also be
I see you’ve posted this problem in
I’m sure an RPI 5 expert will be able to help you but from my brief reading do you know if rpi5 is officially even supported?
Its not, hence why its the preview image
Ah cool, best stick to the other thread, there are smart folk in there trying all sorts of hackery trying to make it work
For me it’s unsupported so I’m out. GL
Thanks for the help. To close the loop incase others have the problem.
It seems like the supervisor network wasn’t working for some reason, as shown in a
supervisor info
The following fixed it
supervisor restart
followed by a
core rebuild
Thanks to @hmadsen
