Hello fellow automation enthusiasts,
I live near an airport, so a lot of airplanes crosses by - at times every few minutes actually. Since this is extremely annoying when listening to media while the window is open (e.g. summer weather and you want to start to cool down the living rooms), I wanted to have a solution other than pausing or adjusting the volume manually each time.
I found piaware, set this one up and wrote an Appdaemon script for home assistant, which queries the piaware instance every 10 seconds for nearby airplanes. When it detects airplanes that are in a specific range around my home and still flying at low altitudes it increases the volume of all active media players specified in the script itself. After the airplane is far enough the volume is decreased again to the old volume level.
For the volume adjustment I used the script HA-Fade-Volume-Script from MaxVRAM (thank you for this!) This allows seamless adjustment (previously had this in steps, this can be quite overwhelming).
Since I thought this could be useful for some others, I wanted to share the script.
If you want to use this, you need to adjust the HOME location to your coordinates, the MEDIA_PLAYERS that should be adjusted, as well as the IP address of your piaware instance.
For improved adjustements you can adjust the HEIGHT and DISTANCE in which the flights are included in further action. Also you can adjust the VOLUME_MODIFIER which regulates the strength of the adjustment.
Also, for each media_player you can set up special conditions (+ attributes) which must be fulfilled for volume adjustment (such as open window sensors).
This might not be the best code especially regarding code quality, but it works well for me
Feel free to discuss changes and/or improvements
AppDaemon Script Code
import appdaemon.plugins.hass.hassapi as hass
from time import sleep
from datetime import datetime, time, timedelta
import requests
import h3
# Debug logs
DEBUG = False
DEBUG_EXIT_REASONS = False
# Home location (for distance calculation)
HOME = (43.3068, 0.7668)
# Configs
VOLUME_MODIFIER = 0.20 # increase by 20% of current volume
HEIGHT_RELEVANT_AIRCRAFTS = 5700 # ignore flights that are higher than 5700 feet (to ignore aircrafts at traveling height)
DISTANCE_RELEVANT_AIRCRAFTS = 2000 # reduce volume if the aircraft is at a distance of 2000 feet
EXCEPTION_FLIGHTS = [''] # if there is one specific flight number circling above your location
# HA Media players
MEDIA_PLAYERS = ['media_player.x']
media_players_increment = {}
media_players_current_level = {}
class PiAware(hass.Hass):
tracked_aicraft = []
tracked_aicraft_steps = []
volume_steps = 1
def is_time_between(self, begin_time, end_time, check_time=datetime.now().time(), debug=False):
# If check time is not given, default to current UTC time
check_time = check_time or datetime.utcnow().time()
check_time = check_time.replace(microsecond=0)
if begin_time < end_time:
return check_time >= begin_time and check_time <= end_time
else: # crosses midnight
if debug:
self.log(check_time)
return check_time >= begin_time or check_time <= end_time
def initialize(self):
self.run_every(self.run, "now+10", 10)
# self restart
self.run_daily(self.restart_myself, "05:10:00")
self.run_daily(self.restart_myself, "17:10:00")
def restart_myself(self, kwargs):
# there were some issues in AppDaemon with the current time so restart the app regularly
self.restart_app("PiAware")
def check_conditions_against_state(self, check_list):
Takes a media player and value to check the state against
Example argument for check_list:
(media_player.x, "playing")
for i in check_list:
if self.get_state(i[0]) != i[1]:
if DEBUG_EXIT_REASONS:
self.log("exit due to " + str(i[0]) + " state being " + self.get_state(i[0]))
return False
return True
def check_conditions_against_attribute(self, check_list):
Takes a media player, attribute and value or list to check the attribute against
Example arguments for check_list:
(media_player.x, "is_volume_muted", False)
(media_player.y", "source", ['DESKTOP-x'])
if type(i[2]) == list:
if not self.get_state(i[0], i[1]) in i[2]:
self.log("exit due to " + str(i[0]) + " attribute " + str(i[1]) + " being " + str(self.get_state(i[0], i[1])) + " and not in list")
self.log(i[2])
return False
else:
if not self.get_state(i[0], i[1]) == i[2]:
self.log("exit due to " + str(i[0]) + " attribute " + str(i[1]) + " being " + str(self.get_state(i[0], i[1])))
return False
return True
def check_not_run_conditions(self):
# the nearby airport is not allowed to have starting planes during the night
if self.is_time_between(time(23,00), time(8,00)):
self.is_time_between(time(23,00), time(8,00), debug=True)
self.log("Airport not operational")
return 1
# some check conditions which must be fulfilled to adjust volume level
check_list = [
("input_boolean.disable_piaware_volume_adjustment", 'off'), #manual switch to be able to turn the automation off in home assistant
("device_tracker.piaware_device", "home"), # piaware device
("person.xy", "home")
if self.check_conditions_against_state(check_list):
# all conditions are fullfilled
return True
else:
# one condition is not fullfilled, so abort
return False
def check_not_run_conditions_media_players(self, media_player):
# specific checks per media_player
match media_player:
case 'media_player.spotify_breph':
# check if source matches PC or laptop
check_list_attribute= [
("media_player.spotify_breph", "source", ['DESKTOP-x']) # check if spotify is playing on my desktop computer (i do not need volume adjustment if it is playing on e.g. the phone)
if not self.check_conditions_against_attribute(check_list_attribute):
# one condition is not fullfilled, so continue
return False
check_list = [
("binary_sensor.pc_running_game", "off"), # i have a sensor in case a game is running (since i have the headset on then i dont need volume adjustment)
("binary_sensor.window_sensor", "on") # only adjust if window is open
if not self.check_conditions_against_state(check_list):
return False
case 'media_player.desktop_pc':
# check if game is running (and therefore not volume modification required)
check_list = [
("binary_sensor.pc_running_game", "off"), # same as above as this is the same room
# one condition is not fullfilled, so return
return False
case 'media_player.lg':
# check window sensor
check_list = [
("binary_sensor.window_sensor_tv_room", "on")
return False
# check if tv is muted
(media_player, "is_volume_muted", False)
return False
return True
def modify_volume(self, inc = True, big_machine = False):
media_players_to_modify_volume = []
for media_player in MEDIA_PLAYERS:
state = self.get_state(media_player)
if state in ['playing', 'on']:
# check special conditions for different media players
if not self.check_not_run_conditions_media_players(media_player):
continue
media_players_to_modify_volume.append(media_player)
if DEBUG:
self.log(media_players_current_level)
for media_player in media_players_to_modify_volume:
if inc:
level = self.get_state(media_player, attribute='volume_level')
increment_value = round(VOLUME_MODIFIER * level, 2)
# cap maximum increment_value
increment_value = 0.05 if increment_value > 0.05 else increment_value
if big_machine:
increment_value *= 2
# create dict for increment_value per media_player
media_players_increment[media_player] = round(increment_value, 2)
media_players_current_level[media_player] = level
level = round(media_players_current_level[media_player] + media_players_increment[media_player], 2)
else:
level = round(media_players_current_level[media_player], 2)
if DEBUG:
self.log("Change volume of "+str(media_player)+" to "+str(level))
# actually increase the volume of the media player
# uses the script from: https://github.com/MaxVRAM/HA-Fade-Volume-Script
# you can also use the service call media_player.volume_up
self.call_service("script/turn_on", entity_id="script.media_player_fade_volume", variables={"target_player": media_player, "target_volume": level, "duration": 1, "curve": "linear"})
# sleep to let the fade volume script execute
sleep(1)
def run(self, kwargs):
# stop if not required to run at all
if not self.check_not_run_conditions():
return
r = requests.get('http://<ip-of-piaware>:8080/data/aircraft.json')
json_airplanes = r.json()
for aircraft in json_airplanes['aircraft']:
try:
altitude = aircraft['alt_baro']
flight = aircraft['flight'].strip()
lat = aircraft['lat']
lon = aircraft['lon']
category = aircraft['category']
big_machine = category == 'A5' # A5 means 4 turbine machine
aircraft_gps = (lat, lon)
# get distance in meters
distance = int(h3.point_dist(HOME, aircraft_gps, unit='m'))
# Exit in case of exceptions (e.g. helicopters for flightseeing)
if flight in EXCEPTION_FLIGHTS:
if DEBUG:
self.log('Skip due to flight being in exceptions list: '+str(flight))
continue
# Exit in case of small aircrafts
if category == 'A0':
continue
if not big_machine:
if altitude < 3500:
# increase the volume more if aircraft is closer than usual
big_machine = True
if flight not in self.tracked_aicraft:
if int(altitude) < HEIGHT_RELEVANT_AIRCRAFTS and distance < DISTANCE_RELEVANT_AIRCRAFTS:
if DEBUG:
if big_machine:
self.log("Flight "+str(flight)+" ("+str(lat) + ", " + str(lon)+"). Height: "+str(altitude)+". Distance to aircraft: " + str(distance) + " - Big Machine")
else:
self.log("Flight "+str(flight)+" ("+str(lat) + ", " + str(lon)+"). Height: "+str(altitude)+". Distance to aircraft: " + str(distance))
self.tracked_aicraft.append(flight)
self.tracked_aicraft_steps.append(self.volume_steps)
# increase volume
self.modify_volume(inc=True, big_machine=big_machine)
else:
if int(altitude) > HEIGHT_RELEVANT_AIRCRAFTS or distance > (DISTANCE_RELEVANT_AIRCRAFTS + 700):
self.tracked_aicraft.remove(flight)
self.volume_steps = self.tracked_aicraft_steps.pop(0)
# decrease volume
self.modify_volume(inc=0, big_machine=big_machine)
except KeyError:
pass
Cheers!
