Hi I tried to get some data by PiAware monitoring but it didn’t work well so I decided to do it by myself.
configuration.yaml:
rest:
- resource: http://piaware/status.json
scan_interval: 300
- name: Piaware Status
value_template: "OK"
json_attributes:
- "modes_enabled"
- "site_url"
- "piaware"
- "uat_enabled"
- "adept"
- "mlat"
- "piaware_version"
- "radio"
- resource: http://piaware/skyaware/data/aircraft.json
scan_interval: 300
- name: Piaware Aircraft
json_attributes:
- "now"
- "messages"
sensors:
piaware_msgs_per_second:
friendly_name: "PiAware Ilość wiadomości/s"
unique_id: "piaware_msgs_per_second"
unit_of_measurement: "msg/sec"
value_template: >
{% set messages = state_attr('sensor.piaware_aircraft', 'messages') | float(0) %}
{% set var_now = state_attr('sensor.piaware_aircraft', 'now') | float(0) %}
{% set last_messages = state_attr('sensor.piaware_msgs_per_second', 'last_messages') | float(0) %}
{% set last_now = state_attr('sensor.piaware_msgs_per_second', 'last_now') | float(0) %}
{% set last_rate = states('sensor.piaware_msgs_per_second') | float(0) %}
{% if messages > 0 and var_now > 0 and last_now > 0 and last_messages > 0 %}
{% set delta_messages = messages - last_messages %}
{% set delta_time = var_now - last_now %}
{% if delta_time > 0 and delta_messages > 0 %}
{{ (delta_messages / delta_time) | round(1) }}
{% else %}
{% if last_rate > 0 %}
{{ last_rate }}
{% else %}
0
{% endif %}
{% endif %}
{% else %}
{{ last_rate }}
{% else %}
0
{% endif %}
{% endif %}
attribute_templates:
last_messages: >
{% set current_messages = state_attr('sensor.piaware_aircraft', 'messages') | float(0) %}
{% if current_messages > 0 %}
{{ current_messages }}
{% else %}
{{ last_messages }}
{% endif %}
last_now: >
{% set current_now = state_attr('sensor.piaware_aircraft', 'now') | float(0) %}
{% if current_now > 0 %}
{{ current_now }}
{% else %}
{{ last_now }}
{% endif %}
piaware_status_1090_radio:
friendly_name: "Piaware 1090 Radio"
value_template: "{{ state_attr('sensor.piaware_status', 'radio')['status'] }}"
icon_template: >
{% if state_attr('sensor.piaware_status', 'radio')['status'] == 'green' %}
mdi:check-circle
{% elif state_attr('sensor.piaware_status', 'radio')['status'] in ['yellow', 'orange'] %}
mdi:alert-circle
{% elif state_attr('sensor.piaware_status', 'radio')['status'] == 'red' %}
mdi:close-circle
{% else %}
mdi:help-circle
{% endif %}
message: "{{ state_attr('sensor.piaware_status', 'radio')['message'] }}"
piaware_status_daemon:
friendly_name: "Piaware Daemon"
value_template: "{{ state_attr('sensor.piaware_status', 'piaware')['status'] }}"
icon_template: >
{% if state_attr('sensor.piaware_status', 'piaware')['status'] == 'green' %}
mdi:check-circle
{% elif state_attr('sensor.piaware_status', 'piaware')['status'] in ['yellow', 'orange'] %}
mdi:alert-circle
{% elif state_attr('sensor.piaware_status', 'piaware')['status'] == 'red' %}
mdi:close-circle
{% else %}
mdi:help-circle
{% endif %}
message: "{{ state_attr('sensor.piaware_status', 'piaware')['message'] }}"
piaware_status_connection:
friendly_name: "Piaware Connection"
value_template: "{{ state_attr('sensor.piaware_status', 'adept')['status'] }}"
icon_template: >
{% if state_attr('sensor.piaware_status', 'adept')['status'] == 'green' %}
mdi:check-circle
{% elif state_attr('sensor.piaware_status', 'adept')['status'] in ['yellow', 'orange'] %}
mdi:alert-circle
{% elif state_attr('sensor.piaware_status', 'adept')['status'] == 'red' %}
mdi:close-circle
{% else %}
mdi:help-circle
{% endif %}
message: "{{ state_attr('sensor.piaware_status', 'adept')['message'] }}"
piaware_status_mlat:
friendly_name: "Piaware MLAT"
value_template: "{{ state_attr('sensor.piaware_status', 'mlat')['status'] }}"
icon_template: >
{% if state_attr('sensor.piaware_status', 'mlat')['status'] == 'green' %}
mdi:check-circle
{% elif state_attr('sensor.piaware_status', 'mlat')['status'] in ['yellow', 'orange'] %}
mdi:alert-circle
{% elif state_attr('sensor.piaware_status', 'mlat')['status'] == 'red' %}
mdi:close-circle
{% else %}
mdi:help-circle
{% endif %}
message: "{{ state_attr('sensor.piaware_status', 'mlat')['message'] }}"
I wrote a simple Pyscript to track how many aircrafts, aircrafts with positions, or MLAT aircrafts are currently visible (the rest service is useless for this - too much data):
import aiohttp
def set_default_sensors():
default_sensors = [
("sensor.aircraft_count", "Ilość wszystkich samolotów", "mdi:airplane"),
"sensor.aircraft_with_position_count",
"Ilość samolotów ze znaną pozycją",
"mdi:map-marker",
"sensor.aircraft_with_mlat_position_count",
"Ilość samolotów z pozycją z mlat",
"mdi:radar",
for sensor_id, friendly_name, icon in default_sensors:
state.set(
sensor_id,
int(0),
"unit_of_measurement": "aircraft",
"friendly_name": friendly_name,
"icon": icon,
"state_class": "measurement",
def set_error_sensors():
error_sensors = [
"mdi:map-marker",
"mdi:radar",
for sensor_id, friendly_name, icon in error_sensors:
state.set(
sensor_id,
int(-1),
"icon": icon,
@service
@time_trigger("cron(*/10 * * * *)")
async def update_aircraft_count():
url = "http://piaware/skyaware/data/aircraft.json"
try:
async with aiohttp.ClientSession() as session:
async with session.get(url, timeout=5) as response:
if response.status == 200:
aircraft_data = response.json()
aircraft_list = aircraft_data.get("aircraft", [])
aircraft_count = len(aircraft_list)
with_position_count = 0
mlat_position_count = 0
for a in aircraft_list:
if all(
[key in a and a[key] is not None for key in ["lat", "lon"]]
with_position_count += 1
if isinstance(a.get("mlat"), list) and len(a.get("mlat")) > 0:
mlat_position_count += 1
sensors_data = [
aircraft_count,
"mdi:airplane",
with_position_count,
"mdi:map-marker",
mlat_position_count,
"mdi:radar",
for sensor_id, value, friendly_name, icon in sensors_data:
state.set(
sensor_id,
int(value),
"icon": icon,
else:
except Exception as e:
log.error(f"Error in update_aircraft_count: {str(e)}")
set_error_sensors()
