I am having issues with getting HA to boot off an SSD.
I have successfully burnt the 64-bit version of the Pi3 image to the SSD but when I plug it into the Pi and turn it on, I get nothing - no flashing green led at all.
Any advice, on getting this working, would be much appreciated.
I am using a Startech USB3.0 to 2.5" cable and my Pi is using the official 2.5A power supply.
I have also tried two different SSDs as well - 60GB Sandisk Ultra Plus and 120GB Samsung 750 EVO.
FYI, I wouldnât spend any more time attempting this. I have the same Startech cable as you and the official power supply and could never get this working. You can read more details here, with a lot of information in that thread. The short of it is that the best you can do is use the officially support method of moving the Data to the USB connected SSD, while still using the SD card for the main OS, which will reduce the bulk of the writes on the SD card.
Actually, I re-read the thread and noticed that Flo was able to get it working on their RPi3B+, so it seems like it might work, I donât have the + version. However, if you follow the steps to ensure USB booting is all enabled then you may get it to work. I still think however there is a limit to which SSDs the RPi3B+ build of HAOS supports.
Here are some other posts to look at details about the success/failure of this setup.
I tried burning HA to a USB stick and that booted fine, so booting from USB does indeed work âout of the boxâ on a 3B+.
I did try copying the contents from the SSD card to a formatted SD card as was suggested in the first of the threads you posted:
"Just to close this off - I got it working booting from SD card then USB SSD. Format an SD card with FAT32 and copy the contents of the âbootâ volume from the USB SSD to the SD card."
However, that did nothing either.
Really confusing - just cannot work out why I cannot get it to work.
@Elsmandino yeah, I also got an SD card in a USB reader to boot on my RPi3B, but I couldnât ever get my SSD to boot. You mentioned that your SSD wasnât available to move data to. Did you make sure that your SSD was fully formatted to the correct format, and made sure any HAOS setup wasnât still on your SSD from previous attempts?
Yeah, that output you are getting is the same output I was getting with my RPi3B. No matter what I tried I couldnât get HAOS to boot off of the SSD. In regards to what format to use on the SSD for use as a data drive I would recommend ext3, though I believe either FAT32 or NTFS may also work.
I tried to add the SSD disk as a data disk, as Tim suggested, but that would not work either.
I then decided to have a go at installing Raspberry PI OS Lite on the SSD and it worked straight away - i.e. without any SD card, just the SSD plugged in.
I then tried the other SSD and that worked perfectly too.
Really does not make sense - seems that the HA image, itself, is causing all the issues.
Have you managed to solve the problem? Experiencing same thing with my Pi3B+.
Booting from Pi OS from SSD works perfectly fine, but HA wonât boot no matter what cable/ssd I try.
Found dirty workaround (without having spare linux laptop):
Install HAOS on SSD. Install Raspbian on SD card. HAOS wont boot, itâll go into Raspbian. SSH into Raspbian. Mount Raspbiansâ /boot partition. Mount HAOS /boot. Wipe clean Raspbiansâ /boot. Copy everything from HAOS /boot from SSD into cleanly wiped /boot on SD card. Reboot. SD card will be used only only to read /boot partition and itâll boot into HAOS located on SSD.
Not ideal solution - since SD card needs to be inserted, but at least it isnât used for anything except reading /boot partition during startup.
First I tried setting up a new instance on the ssd via the RPi Imager, but couldnât get the backup restored in any way. The onboarding restore is mediocre at best, a dummy onboarding plus restore led to âsystem is damagedâ error and seemingly nothing to do to repair it.
Then I created an image with dd ... command and flash it with RPi Imager, no go.
Then I used balena etcher and cloned the sdcard to the ssd directly and voilla, it works beautifully⌠For now
