Pick Server port not showing, three bullets are gone
Hallo,
I tried to install a ESP32 module in ESPHOME
I need to select the server usb port to install over usb. But the three bullets on the right side are not showing up. I see only “update all” end “secrets”.
Any insigt welcome!
Home Assistant OS 6.6
supervisor-2021.12.1
ESPHome Current version: 2021.12.0
If you’re adding a new device, click the new device button in the lower right corner. Otherwise, use the 3 vertical dots on the device you want to update.
Not good , Yes I added new device, edited the .yaml and then install, ask for “Pick server port”
normaly I can select right up right of secrets three bullets, they are gone!
Click the 3 dots on the new device (not in the upper corner)… then click install… then choose which method you want…
Yes i did exactly that and I get:
4
Next I have to connect the usb port. But the three bullets to do that are gone.
The USB device will be found on that page. If it’s not showing up then there’s an issue with your hardware. Make sure you’re actually using a data cable and not just a charging cable. Also make sure you’re plugged in before starting the process.
