Picked up Docker Wyze Bridge project updates
Since mrlt8 has been busy of late, I created a fork and merged the PR changes that have been pending for a while. Not trying to steal thunder, but I needed a stable source for updates.
The repo does all the Docker Hub publishing and everything, so feel free to click the ADD ADD-ON REPOSITORY button in the repo GitHub - IDisposable/docker-wyze-bridge: WebRTC/RTSP/RTMP/LL-HLS bridge for Wyze cams in a docker container or grab the new docker image from here
Are you still updating?
Today the Wyze Pan V4 is out.
Will it also work with your fork?
I second that. pan cam v4 is awesome and would like to see it added
does this fork work? i tried installing from main on new HAOS/RPi5 today and it authenticates, pulls camera info, but does NOT load any images.
I switched from mrlt8 to this one today for my v4 camera. Changed the image, pulled down new docker and started it. I don’t think the rtsp and rtmp streams worked in the wyze bridge gui before and don’t play in this one for me. The streams are working though. Since I changed and use Frigate, I had to make one small change in my Frigate config file. I use the HLS stream and had to change the url file name.
Can you show us how?
Cause the RTSP stream in VLC is not working, but is an HLS strem also possible?
Has anyone got the V4 working?
I have 4 V3 all working but can’t get the V4 stream working in wyze bridge.
I am seeing the same thing for about 15 days now. V4 and Pan V3 no longer working. V4 firmware is 4.52.9.5332 and Pan V3 is 4.50.15.5336.
It’s been a VERY long time, but I’m back… and the add-on has been completely rewritten from scratch in Go using modern HA Add-on idiom
It works great for any TUTK-based cameras… working on the GWell now…
Just curious what moving to the new build looks like on our end. Is it as simple as I installing the old docker wyze bridge that's no longer showing up in the addon repository and install the new one? Do we need to reconfigure all of our cameras?
Nevermind I just found the migration document on the GitHub
Hello @IDisposable !
First thanks for doing this!
I am using docker compose:
  wyze-bridge:
    image: idisposablegithub365/wyze-bridge:go
    restart: unless-stopped
but I got the error:
pi@rpi5:~ $ docker compose up wyze-bridge
[+] up 1/1
 ✘ Image idisposablegithub365/wyze-bridge:go Error manifest for idisposablegithub365/wyze-bridge:go not found: manifest unknown: manifest unknown        0.7s
Error response from daemon: manifest for idisposablegithub365/wyze-bridge:go not found: manifest unknown: manifest unknown
Looks like there's no such "go" tag in:
https://hub.docker.com/r/idisposablegithub365/wyze-bridge/tags
Did I miss something?
OK, I used the "latest" tag and it seems to pick up version 4.3.0 which is indeed the latest.
But I can't connect the RTSP streams on my Wyze V3 cameras even though the log seems to say the cameras are discovered and connected.
Anyone has the same problem?
thanks
