I am using a Pico remote via zigbee2mqtt and it exposes an action for each button so I created an automation for the top button to turn on a light, the dim up to turn the light to 50%, dim down to 25% and bottom button for off. The issue is whenever I press the dim up/dim down button, the light turns on to the correct brightness and quickly turns off. I troubleshooted this for a long time finally realizing that the automation I created for the last button uses an action called brightness_stop which I assume its listening to when the button is released so hence why the dim button automations don’t properly work.
Any idea how to make this work? Anyone using this remote can chime in on a correct way to automate/use its buttons?
