I’m trying to setup a local audio output on my pi3. After reading a bunch of threads, I went with vlc-nox and picotts but I’m stuck with no sound from HA.
Running 0.37.1 AIO installer, I have this in my config:
tts:
- platform: picotts
language: 'fr-FR'
media_player:
- platform: kodi
host: yoda
username: xbmc
password: !secret xbmc_password
- platform: vlc
in my script yaml:
test_vlc:
sequence:
- service: tts.picotts_say
entity_id: media_player.vlc
message: 'Que la force soit avec toi.'
test_kodi:
sequence:
entity_id: media_player.kodi
Test_kodi is working well. Test_vlc is not playing.
After different things, I can say:
wav file is created in /.homeassistant/tts
wav file can be played in command line with pi user
wav file can’t be played in command line with homeassistant user:
pi@pi:/home/homeassistant/.homeassistant/tts $ sudo su -s /bin/bash homeassistant
homeassistant@pi:~/.homeassistant/tts$ ls
c6832f313b8a4fd38a2f0ee1eb91a13a59d4249e_fr-fr_-picotts.wav
homeassistant@pi:~/.homeassistant/tts$ vlc c6832f313b8a4fd38a2f0ee1eb91a13a59d4249e_fr-fr-_picotts.wav
VLC media player 2.2.4 Weatherwax (revision 2.2.3-37-g888b7e89)
[009f0550] core interface error: no suitable interface module
[009d08f8] core libvlc error: interface “globalhotkeys,none” initialization failed
[00a689b8] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[00a689b8] core interface error: no suitable interface module
[009d08f8] core libvlc error: interface “dbus,none” initialization failed
[009d08f8] core libvlc: Running vlc with the default interface. Use ‘cvlc’ to use vlc without interface.
[009f0608] [cli] lua interface: Listening on host “*console”.
Command Line Interface initialized. Type `help’ for help.ALSA lib confmisc.c:768:(parse_card) cannot find card ‘0’
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_card_driver returned error: No such file or directory
ALSA lib confmisc.c:392:(snd_func_concat) error evaluating strings
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_concat returned error: No such file or directory
ALSA lib confmisc.c:1251:(snd_func_refer) error evaluating name
ALSA lib conf.c:4259:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:4738:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2239:(snd_pcm_open_noupdate) Unknown PCM default
[00a6eee0] alsa audio output error: cannot open ALSA device “default”: No such file or directory
[00a6eee0] core audio output error: Audio output failed
[00a6eee0] core audio output error: The audio device “default” could not be used:
No such file or directory.
[00a6eee0] core audio output error: module not functional
[75a01a38] core decoder error: failed to create audio output
I’m not sure what or where to look at.
Thx for any advice.
