I’ve copied in the WWW folder two pictures jpg.
One downloaded from internet and one done with my IPhone.
When in the element settings I insert the path of the picture downloaded from internet the picture is shrewd correctly.
But when I try with the picture from IPhone the card show nothing.
I thought about that but are JPEG.
Thinking about a strange property of the pictures I took a snapshot and utilized it in HM, but nothing also in this case.
As far as I know, there are no size or resolution limitations. If you try to go to the picture directly in the browser (http://<ha address|name>:8123/local/picture.jpg), does it render?
That means that the picture isn’t in a usable format. You’ll need to convert it first to jpg, png, etc.
You can further prove this out by uploading the image to any number of image conversion websites (I like Image Converter - FreeConvert.com myself), convert it, and then save it back to HA and see if it renders.
I believe there are some resolution limitations when applying images into smaller constraints. I’ve tried some high res background-images with shape backgrounds and had to shrink the image to make them appear.
Hi Asky, i changed you Topic Header, to reflect your real issue, it’s never a good idea to assume something don’t work, unless one is certain, that it’s broke (somehow)
Please also “Mark” Bill’s(code-in-progress) answers as the Solution, so other people in same situation might find this when using the Search-Function
Also, in case you didn’t know… you can convert automatically on the phone using Shortcuts and I think you can upload it to HA that way. Definitely something for you to play around with (if you aren’t already).
