jugla
April 16, 2020, 10:24am
1
I’ve just found the picture-element https://www.home-assistant.io/lovelace/picture-elements/
I drawn my appartment plan , and I wanted to change the color of my PC depending on its state (whether it is on or not).
I have a device tracker that say “home” or “not_home”.
I don’t know how to do it in a easy way. What I have done is with a conditional element.
Here after the PC is call bonite and device tracker is managed by my freebox.
The PC icon comes green if at home and red if not
type: picture-elements
title: state of device (action=history)
elements:
- type: conditional
conditions:
- entity: device_tracker.bonite_2
state: home
elements:
- type: state-icon
title: PC Windows
style:
top: 28%
left: 34%
'--paper-item-icon-color': green
- type: conditional
conditions:
state: not_home
elements:
- type: state-icon
title: PC Windows
style:
top: 28%
left: 34%
'--paper-item-icon-color': red
image: /local/plan_home_N.jpg
I would like to use a template . For instance in '--paper-item-icon-color': red
But no way.
Any idea ?
jugla
April 16, 2020, 1:04pm
2
jugla
April 16, 2020, 2:14pm
3
Here a solution with card-mod (get idea from https://community.home-assistant.io/t/card-mod-add-css-styles-to-any-lovelace-card/120744/102 )
Add in the main part of picture-element
style: |
ha-card {
--my-color-plug-balcon: {% if states('device_tracker.meross_smart_switch_2') == "home" %} green {% else %} red {% endif %};
--my-color-cpl1: {% if states('device_tracker.cpl1200ac_1_2') == "home" %} green {% else %} red {% endif %};
and use these variables inside elements
elements:
- entity: device_tracker.meross_smart_switch_2
icon: 'mdi:power-socket-eu'
style:
left: 15%
top: 35%
'--paper-item-icon-color': var(--my-color-plug-balcon)
title: main plug
type: state-icon
- entity: device_tracker.cpl1200ac_1_2
icon: 'mdi:power-plug'
style:
left: 65%
top: 49%
'--paper-item-icon-color': var(--my-color-cpl1)
title: CPL1
type: state-icon
It 's an ok solution since the color definition can be more complicated (e.g. different threshold for a battery)
jugla
April 17, 2022, 8:36pm
4
Since HA 2022.4.x, you have to say you want to overwrite state_color.
elements:
state_color: false
style:
left: 15%
top: 35%
title: main plug
type: state-icon
state_color: false
style:
left: 65%
top: 49%
title: CPL1
type: state-icon
hmmm, trying out to color an icon in regards of a humidity sensor here. Cant get it to work. have i forgotten something? Wont save like this .
style: |
ha-card {
--my-color-humidity: {% if states('sensor.bad_feuchte')|float > 70 %} red {% else %} green {% endif %}
elements:
- type: state-icon
entity: sensor.bad_feuchte
state_color: false
style:
top: 29.7%
left: 33.5%
'--paper-item-icon-color': var(--my-color-humidity)
opacity: 65%
image: /local/Raumplan.png
jugla
February 11, 2023, 3:15pm
6
Please, in which color , you see your device ?
blue, atm as it is the normale state color.
jugla
February 11, 2023, 6:33pm
8
Please can you add ; at the end of --my-color-humidity: {% if states('sensor.bad_feuchte')|float > 70 %} red {% else %} green {% endif %}
Msmax
October 10, 2023, 10:00am
9
Thanks. This was very helpful.
Been struggling for hours and this solved my icon color problem.
kkdahl
(Kkdahl)
January 9, 2024, 9:54pm
10
Found this post and thought; finally!
But I can’t get it to work, it will not fetch the variable-defined color. It only shows the default blue icon-color. What am I doing wrong?
(Yes, I have the card-mod )
image: local/test-floorplan.jpg
style: |
ha-card {
--my-color-vindue-kontor: {% if states('binary_sensor.kontor_sensor_vindue_contact') == "open" %} red {% else %} green {% endif %};
elements:
- type: state-icon
entity: binary_sensor.kontor_sensor_vindue_contact
icon: mdi:window-closed
state_color: false
style:
left: 80%
top: 80%
'--paper-item-icon-color': var(--my-color-vindue-kontor)
kkdahl
(Kkdahl)
January 10, 2024, 1:04pm
11
Got it to work:
card_mod:
style: |
:host {
--color-vindue-kontor: {% if states('binary_sensor.kontor_sensor_vindue_contact')== 'on' %} red {% elif states('binary_sensor.kontor_sensor_vindue_contact')== 'unavailable' %} grey {% else %} green {% endif %};
elements:
- type: state-icon
icon: mdi:window-closed-variant
state_color: false
style:
left: 80%
top: 80%
'--paper-item-icon-color': var(--color-vindue-kontor)
jugla
January 10, 2024, 8:38pm
12
Thanks for the new way to use card_mod.
Wingnut
(Graham Richards)
January 12, 2024, 4:48pm
13
kkdahl:
Got it to work
I just tried your solution but it only shows the required color in the off state. Once on I get the default yellow. Here’s my code in case I got something wrong.
- type: picture-elements
image: /local/FloorPlanGround4FirePanel695Y.jpg
card_mod:
style: |
:host {
--color-vindue-kontor: {% if states('light.socket5')== 'on' %} purple {% elif states('light.socket5')== 'unavailable' %} grey {% else %} blue {% endif %};
elements:
- type: state-icon
entity: light.socket5
icon: mdi:television-ambient-light
tap_action:
action: toggle
style:
top: 25%
left: 70%
'--mdc-icon-size': 40px
Can I change the --color-vindue-kontor: bit to something in english.
kkdahl
(Kkdahl)
January 30, 2024, 9:05am
14
Try adding “state_color: false”
and the --color-vindue-kontor is just a variable, you can change that to anything you want.
card_mod:
style: |
:host {
--whateveryouwant: {% if states('light.socket5')== 'on' %} purple {% elif states('light.socket5')== 'unavailable' %} grey {% else %} blue {% endif %};
elements:
- type: state-icon
state_color: false
tap_action:
action: toggle
style:
top: 25%
left: 70%
'--paper-item-icon-color': var(--whateveryouwant)
Th_User
February 7, 2024, 8:57am
15
for some reason this is not working?
image: /local/ioniq5/HomeScreen.png
width: 100%
hight: 100%
card_mod:
style: |
:host {
--whateveryouwant: {% if states('binary_sensor.ioniq_5_engine')== 'on' %} purple {% elif states('binary_sensor.ioniq_5_engine')== 'unavailable' %} grey {% else %} green {% endif %};
elements:
- type: state-label
entity: sensor.ioniq_5_total_driving_range
style:
top: 10.7%
right: 15%
font-size: 200%
- type: custom:bar-card
entity: sensor.ioniq_5_ev_battery_level
positions:
icon: 'off'
value: inside
style:
top: 6.5%
left: 10%
background: none
box-shadow: none
text-shadow: none
transform: none
overflow: hidden
border-radius: 0px
width: 38%
height: 25px
min: 0
max: 100
severity:
- color: Red
to: 25
- color: Orange
to: 50
- color: Green
to: 100
- type: state-icon
entity: binary_sensor.ioniq_5_engine
icon: mdi:power
state_color: false
style:
top: 22%
left: 15%
transform: scale(2.3,2.3)
Th_User
16
nevermind works but not in the preview xD
sorry!
homie22
October 20, 2024, 8:51pm
18
This works!
But how would I do it, if I have more than one light?
I wouldn’t want to repeat the code x-times for each light.
Wingnut
(Graham Richards)
September 12, 2025, 3:57pm
19
I know this was a while ago but I finally got it to work on another card I’ve started working on with the following code:
card_mod:
style: |
:host {
--pyloncolor: {% if states('switch.battery_charger')== 'on' %} red {% else %} blue {% endif %};
elements:
- type: icon
icon: mdi:transmission-tower
style:
left: 10%
top: 10%
"--mdc-icon-size": 60px
color: var(--pyloncolor)
But now when I go back into picture elements editor, the card_mod section has gone, so it now looks like this
elements:
- type: icon
style:
left: 10%
top: 10%
but it still works ie the pylon changes colour when I switch the battery charger on!
My question now is - Where can I get to the definition of the variable pyloncolor and edit it if need be?
