Hello
I make some picture element floor plan, and i need use custom:grid-layout in my actual hui-element config.
Unfortunately, it doesn’t want to work for me.
I would like after changing the state of the button below:
# MENU nowy PARTER
- type: conditional
conditions:
- entity: input_boolean.pietro
state: "off"
elements:
- entity: input_boolean.menu_parter
style:
top: 84.5%
left: 65%
show_entity_picture: true
show_name: true
styles:
card:
- height: 165px
- width: 150px
name:
- font-size: 16px
label:
- font-size: 10px
- color: transparent
icon:
- width: 110%
- color: white
tap_action:
action: toggle
type: custom:hui-element
row_type: custom:button-card
additional menu to appear in the format custom:grid-layout
I tried something like this but unfortunately it didn’t work:
- type: conditional
conditions:
state: "on"
layout:
grid-template-columns: auto 30px 25%
grid-template-rows: auto
grid-template-areas: |
"header header header"
"main . sidebar"
"footer footer footer"
mediaquery:
"(max-width: 600px)":
grid-template-columns: 100%
"header"
"sidebar"
"main"
"footer"
"(max-width: 800px)":
grid-template-columns: 50% 50%
"header sidebar"
"main main"
"footer footer"
cards:
- type: entities
entities:
- entity: light.bed_light
title: "1"
show_header_toggle: false
view_layout:
grid-area: header
row_type: custom:grid-layout
Why do you use custom cards inside hui-element card?
The 2nd code is an impossible mix of custom-layout card with Entities card & Conventional card.
Probably you should explain what design you want to create?
First of all thanks for your interest I have this floor plan:
I want to model the menu on something like this:
for a better explanation: i want to gropu card in grid 2x2
on picture element card using for this Grid Card - Home Assistant
for now i’m doing it one button at a time manually but i’d prefer grid if possible
As I said, this is a mixed code.
You are using option from a card X inside a card Y.
Suggest you to:
Remove conditional card, make it simple. You will add it back when other parts are ready.
Then you have a layout-card containing a left stack & a right floorplan. Go to layout-card thread & then find out a proper code for this layout-card.
Hi, could you send the code, how to configure picture elements backround with that card layout on the left and the second card on the right?
i don’t know how to set up cards in a card inside of a picture element and that would help me understanding it
Thx
meibye
(Meibye)
November 3, 2023, 6:21pm
6
I am fairly new to HA and picture-elements and have experienced problems related to positioning state-label elements within nested custom:grid-layout. I have followed the instruction in this post without the expected result.
I am trying to make use of nested grids in order to get better control of the positioning of the individual cards. I am using grid area names when naming and allocating. My intention is to create a grid as shown in the picture below with grid-lines, where the value of the state-label card with picture-elements is centered horisontal and vertical in the grid element. The nested grid is placed within the grid element named g5, which is divided into 2 columns.
As can be seen in the picture I can not get the correct height on the grid element g1, which is a state-label card. The card in the nested grid element b5 where the title is shown, also shows the same behaviour that the state-label value is not centered vertically in the area below the title. The blue line indicates the first pixel line after the title.
My configuration is
- title: Pic-elem Grids
layout:
grid-template-columns: 1fr 1fr
"g1 g1"
"g2 g3"
"g4 g5"
cards:
- type: picture-elements
state_filter:
- null
image: /local/assets/blue1x1.png
# title: "g1"
aspect_ratio: 1%
view_layout:
grid-area: g1
elements:
- type: state-label
entity: sensor.local_sunrise
style:
top: 50%
left: 50%
font-size: 2.8rem
background-color: coral
- type: entities
entities:
- sensor.time
title: "g2"
view_layout:
grid-area: g2
- type: entities
entities:
- sensor.time
# title: "g3"
view_layout:
grid-area: g3
- type: entities
entities:
- sensor.time
# title: "g4"
view_layout:
grid-area: g4
- type: "custom:layout-card"
layout_type: grid
layout:
"a5 b5"
view_layout:
grid-area: g5
cards:
- type: entities
entities:
- entity: sensor.time
title: "a5"
view_layout:
grid-area: a5
state_filter:
- null
title: "b5"
aspect_ratio: 1%
view_layout:
grid-area: b5
elements:
- type: state-label
entity: sensor.local_time
style:
top: 50%
left: 50%
font-size: 2.8rem
I would appreciate any guidance in getting the results I try to achieve.
