Image doesn’t show up in the picture element. Any problem with the coding?
Yes. Use /local/ for URLs, use /config/www/ for paths.
I just had a look at the docs. Apparently you can use /local to specify the image path according to the examples. So ignore that advice.
Did you restart after creating the www folder?
I try ‘image: /local/floor_plan/all_off.png’ again. It works.
may be i did not restart the server just now. Thanks.
