I faced unexpected problem with picture elements state label from timer entity.
Timer itself says correctly:
Finishes at
October 5, 2024 at 11:15:23
But in picture elements the date is in format:
2024-10-05T08:15:23+00.00
And I’ve not found a way to overcome this. Except creating separate helper with value template and that is probably bit overkill for my nice-to-have feature atm.
Is there any way to fix it? Should I submit a bug for it or is this intended functionality?
Picture elements may not show a desired format, cannot test myself. Probably a good feature request.
Entities card may show you a desired format.
So, place your entity on the Entities card, place the Entities card on the Picture elements card as a custom element, card-mod this element to remove borders and background to make it looking like a state-label. Long way.
If even a standard row in Entities card does not give you a desired look - then use template-entity-row inside that Entities card))) and define a templated state look manually.
Btw creating new helper template sensor was pretty simple to implement and it provides times at correct timezone. It can be added directly as state-label and all seem to be correct.
My template in case someone is scratching their head with same issue:
